Author: Subject: Speed Sensor
pekwah1
posted on 27/4/11 at 11:46 PM Reply With Quote
Speed Sensor
Hi Guys,
I need to get a magnetic speed sensor sorted out for my kit.
Problem is i'm struggling to actually find one.
Any ideas where i should be looking and how much they go for?
Thanks,
blakep82
posted on 27/4/11 at 11:52 PM Reply With Quote
http://www.rallydesign.co.uk/product_info.php?cPath=412_1824_1878&products_id=10545
that should do for just about every electronic gauge
or burton sell one that goes in the type9 gearbox for electronic gauges, think it work s out to about £50 once the sensor, the gearbox adapter, vat and post are added up
________________________
snowy2
posted on 30/4/11 at 10:52 AM Reply With Quote
I have made my own magnetic speed sensor for my car, you need a strong magnet (button type) and an easy source for these is the cheap pick up tools from markets, and a mico reed switch, these are available from Maplins for 20p or so. The double acting switches are the most reliable in my experience, and you need to select the normally open terminal. Contrary to what seems most likely these switches work best if they are presented to the magnet "end" on and not parallel to it. you will need a non magnetic housing to put it in and to secure it to the car, the magnet needs fixing to your wheel some where (i use the rear of the hub) when bending the reed switch legs use needle nose pliers as the glass case they are fitted into is very fragile and they break easily. Use and epoxy glue to secure the reed switch into a suitable holder (or a good alternative is silicone sealant)
the sensor has been very reliable in use and works very well.
sometimes you are the pigeon, most of the time the statue.
