BATHO
posted on 28/4/11 at 07:30 AM |
wiring 1.8 zetec
Hi all,
im planing fitting a standard 1.8 zetec into my locost. The engine is out and now im wondering which wiring will i need from the doner to
make the engine run, ( ie what does the ECU need to read of ). I do not require lights etc just the basic running electrics or is it just one big
mixed loom for the car, if anyone could help.
cheers
mad4x4
posted on 28/4/11 at 11:41 AM |
For the injection you will need :
the Edis Box (Depends ion ECU)
The coil Pack
the ECU
the Air Box senor
the Oil Sensor
the crank sensor
the cam sensor
the injectors
Lamda sensor
spark plugs & leads
TPS sensor from the pedel if it is fly by wire
ECU
injector Loom
You will need a High pressure fuel Pump & Swirl Pot
anything iv'e missed please feel free to add?
Scot's do it better in Kilts.
big_wasa
posted on 28/4/11 at 08:38 PM |
Whats the donor ? I could give you a better idea.
BATHO
posted on 29/4/11 at 02:47 PM |
Hi, thanks for the reply's the doner is a 1998 Mondeo LX 1800 zetec.
I have taken out the main engine bay loom from the ECU............
big_wasa
posted on 29/4/11 at 03:13 PM |
Being the Mondeo you will have the eec-v ecu, thats 104 pins of wiring fun. NO external edis4 unless its an automatic.
http://youtu.be/BKqeCjdBM0w
You need the engine loom from the ecu as you say upto the 42 pin plug on the N/s inner wing. The ecu. You want the ignition key and barrel. Around the
key is the Pats Antenna, you want that and the plug with as much wire as you can free up. Whilst your in that area you will also want the OBD2 port /
Sensors, you want all the ones on the engine, inlet, exhaust. Give me a shout if your not sure.There are a few external sensors to the engine loom but
you dont need them / can not fit them. Ie clutch position sensor and fuel tank evap' valve.
If you can fit the inlet manifold in your car it will make it easier and cheaper. If you can fit the engine loom as it comes from the mondeo you will
save your self a lot of work.
To chop the loom up and make it fit a car takes me 40 hour or more. To wire that 42 pin plug up is 10 hours or less.
The ecu controles the mondeo alternator aswell but You dont have to use it.
hope that helps.
BATHO
posted on 29/4/11 at 04:09 PM |
Brilliant, yes the 42 pin plug looks like loads of fun.........Any chance of some more info on the OBD2 port as cannot find it in the book to find
out what it looks like or does. As for the sensors, i have kept most of them in place on the engine and you mentioned the external sensors i.e clutch
position sensor and the fuel evaporation valve, do you just leave them unplugged and the engine will still run without them? I want the easiest route
possible so i am going to try and use the original inlet manifold and alternator.
Cheers and thanks in advance.
big_wasa
posted on 29/4/11 at 05:00 PM |
One ive done for a bench engine.
I can plug that into an engine loom with a fuel pump and battery ect and have it running on the garage floor.
http://youtu.be/Pxq4ks2Us_U
I remove all the sensor wiring I dont use. Less chance of shorting, less bulk and looks neater.
I bin the load sensors such as clutch pos' heated windows Air con ect. These up the rpm at idle to stop stalling. I also bin the egr,
evap', and anything elts that dumps oil vapour into the inlet manifold for it to go crusty. This does give three error codes in the ecu but
doesnt seem to affect it. Being pre OBD2 it has the diagnostics but no MIL light. Its not fully OBD" compliant.
There are other functions such as the smart charge on the alternator. Coolant fan controle. Ac controle aswell as Ac load sense.
Important sensors are.
Maf, Lambda, Tps, Cps, Cam phase, ECT, IAT. And not a sensor but the Iacv. Iat is built into the Maf on the blacktop.
Obd2 function is great as you can plug it up to a cheap scanner and see what its all doing.
Obd2 plug is below steering column. It should be with in reach of the drivers seat on any car.
All a bit random
[Edited on 29/4/11 by big_wasa]
big_wasa
posted on 29/4/11 at 05:15 PM |
For ideas on fitting with the standatd inlet see
It needs a dog leg in the steering link of a locost and removing the Y brace in the engine bay.
The plastic plenum was sold by westfield. A mate of mine says its from an early diesel Pug ?
big_wasa
posted on 29/4/11 at 05:21 PM |
This is mine
Ive done a revamp over the winter and replaced the fancy Race line water rail with the standard stat and silicone
Much better.
BATHO
posted on 1/5/11 at 10:00 AM |
Cheers for all the info it's helped loads, ive got a better picture now of what i need.
Liking ya engine testing bed/frame, i might try and make one and go from their.
BATHO
posted on 24/8/17 at 03:22 PM |
Hi can you wire this Zetec silver top 1998 with pats
Straight from the 42 pin plug?
If so do you have a drawing?
I've done to power supplies one for ecu the other for fuel pump.
Hope you can help
big_wasa
posted on 24/8/17 at 07:46 PM |
Yes but I've never done it direct to the 42 pin plug as it puts the ecu over the offside front wheel.
I cut th loom up and move the ecu to the bulk head.
big_wasa
posted on 24/8/17 at 07:48 PM |
My work.
http://www.locostbuilders.co.uk/viewthread.php?tid=179921
big_wasa
posted on 24/8/17 at 07:52 PM |
And turnipfarmers work bassed on mine and can be easier to understand than mine.
http://www.locostbuilders.co.uk/forum/47/viewthread.php?tid=183643
BATHO
posted on 24/8/17 at 10:30 PM |
Do you know what goes where on the 42 pin plug,
Or could you give me a list with the numbers and there destination?
Do you make the looms to sell?
