rf900rush
| posted on 11/5/11 at 04:22 PM |
Indicator / Hazard Relay Board DIY
Hopefully solved my messy Indicator/Hazzard wiring, with my homebrew PCB
If it works as designed, it should now reduce the complex wiring to get round using a Savage Hazzard switch.
Plus no worries upgrading to LED lights as well.
  Indicator PCB
Martin
daniel mason
| posted on 11/5/11 at 05:05 PM |
looks good but all you need to get the savage hazard switch working correctly is;
1; a pair of diodes
2;a flasher relay (led flasher if required)
although yours definately tidies things up a bit
