-matt
posted on 15/5/11 at 05:30 PM |
R1 rev signal?
Sorry another wiring question.
How do i get the revs signal from a 2008 R1 to my acewell 3252 digidash?
From what i can tell from the manual i need to connect the 1 cable to the ignition coil? But which wire and which coil?
And then need to input the revelutions per second? The choices are 0.5,1,2 or 3?
So can anyone help me with this?
MK9R
posted on 15/5/11 at 05:39 PM |
Se the yellow wire with black trace from the ecu that feeds the bike clocks
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
-matt
posted on 15/5/11 at 10:57 PM |
thanks, i will give that a go.
can anyone tell me how many revolutions per signal/pulse there are though, so i can have it set right?
mad-butcher
posted on 16/5/11 at 08:08 AM |
think it's .5 because it's wasted spark. you'll soon tell anyway if you get it wrong, My R1 ticks over at about 1000 rpm so acewell
tacho if on wrong setting will either read 500, 2000,3000, so easy enough to alter if set wrong .
tony
