hubby
| posted on 20/5/11 at 09:20 AM |
ALTERNATOR CONNECTIONS WHATS WHAT
HI ALL new here and to kit cars so please bare with me
i have a new alternator unipart gxe2291 it has the 3 normal spade connectors 2 large which are joined and the smaller one it also has a stud and nut
with the letter W next to it and bolted next to it there's a little black box with a wire running to another spade terminal and next to it
there's another stud and nut with a plastic cover and between them there's the letter B+ so my question is do i do any thing with the 2
studs/nuts that are marked up W and B+ as my car only has the 3 spade connectors thanks
| posted on 20/5/11 at 09:43 AM |
W+ : rev counter
B+ : Main output - normally connected directly to the positive terminal on starter solenoid. From there there should be a thick gauge cable to the
positive terminal on the battery
... best post a photo if you can.
hubby
| posted on 20/5/11 at 12:35 PM |
thanks for that
as im new to this and you said add a picture how do i do it ive uploaded a pic to my archive but for the life of me cant work out how to put it on a
post. thanks
Miks15
| posted on 20/5/11 at 01:15 PM |
above the photo in your archive there is a code. Copy and paste that in to the post
It will look like this [pg]79939 [/pg] (without the space after the number.
And the pic will come up like this:
  alternator
[Edited on 20/5/11 by Miks15]
