<<  1    2  >>
Author: Subject: ride height adjustments...coilover questions
first350
posted on 21/5/11 at 03:14 PM Reply With Quote
I'm trying to dial in my suspension, and all of the coilovers I've worked with have been on cars....and these are fairly different.
specs:
-Inboard front
-Miata donor
-195/50/15 tires (R888's)
-goal: front lower control arms level w/ ground and Rear about 10mm higher than front.
Questions:
1) The lower spring perches only have 1 collar...does the weight of the car keep that in place? (I've always had 2 collars, that can be tightened to each other to lock in the height)
2) To get my rear low enough, the spring collar is threaded so far down that when the car is on jack stands, the springs are loose. Is this ok? (I've seen other car coilovers that use "spring helpers"...basically a 2nd thin spring that doesn't add any force, but takes up the slack when the car is on jack stands)
coilover w/ spring helper:
here's a pic of the front coils...this is how my rear look to get the right height (the spring is loose)
Cheers!
bassett
posted on 21/5/11 at 04:02 PM Reply With Quote
I remember mine feeling a bit loose but the weight soon takes care of that and all of them only have one spring i guess due to the short length
tomgregory2000
posted on 21/5/11 at 04:18 PM Reply With Quote
mine have a grub screw in them to keep them in place
Davey D
posted on 21/5/11 at 05:00 PM Reply With Quote
on the back of mine if i have it on axle stands the springs drop from the top cup. once it is dropped to ground though they always relocate with an un-nerving twang noise :-)
first350
posted on 23/5/11 at 01:43 PM Reply With Quote
mine did that too - freaked me out the first few times!!
Once I get the ride height right, I'll make some marks on the shocks bodies so that I can see if the spring collars/perches move over time. It'll be a good excuse to put as many miles on it as possible
BigLee
posted on 23/5/11 at 08:31 PM Reply With Quote
Thank god its not just me!! I had planned to get to the bottom of this problem tomorrow by removing most of the suspension and checking I hadn't got all the springs/shocks the wrong way around. Thats saved a job, but doesn't answer why this happens? Surely a shorter damper body should be used. Seems a little half arsed. Unless someone can explain the benefit of your wheels dropping in this manner when in the air?
Lee
Agriv8
posted on 24/5/11 at 06:40 AM Reply With Quote
its normal - never known a colar move and as the do not rotate ( as the are bolterd into the mounting bracket) there is little roational force on them. They locate them selves very well when dropped to the ground though the first few times you get a big "Twang" as the seat will make you Jump
Ps the dampers are the length they are due to availability and cost a better I belive also sring strength and length is a factor. though the main reason is to save weight as the same basic chassis are used for the EC boys where shaving every Ounce is important.
hope that helps ATB
Agriv8
[Edited on 24/5/11 by Agriv8]
BigLee
posted on 24/5/11 at 11:53 AM Reply With Quote
Thanks for the info. Still sounds a bit iffy though. So when the car is "light" ie over a bump or hump back bridge ( in the extreme) then you have no suspension provided by the spring, it looks like the damper is too long or the spring too short.
Lee
Frosty
posted on 24/5/11 at 02:18 PM Reply With Quote
If the spring is slack then definitely get some helper springs in there, or a shorter spring.
Windscreen Wipers
Need windscreen wipers for your car? Order from a friendly kit car owner.
Don't pay a garage to do them. You built a car for God's sake - I'm sure you can fit your own wipers!
procomp
posted on 24/5/11 at 08:13 PM Reply With Quote
Hi
The spring length on that first pic can't possibly be right. The spring is wound up towards the top end of its height adjustment. When the car is sat at static ride height the damper would only have 25 ish mm before siting on the bump stops. There is absolutely no room for movement in droop before the spring is unloaded.
It's quite common for the spring to become unloaded at full droop of the damper IE when the car is on a jack out of normal working range. But to have no load in the slightest of droop travel is ridiculous. Something is wrong with that setup.
Cheers Matt
BigLee
posted on 24/5/11 at 09:06 PM Reply With Quote
Rear shocks on mine. I presume the same as first350's as our chassis's were about 2 weeks apart. When the shock is fully extended by winding out the preload (no actual preload on the spring - just the slack taken up) the back end was sky high. Now wound down to get the ride height correct, but blows through half the damper travel. I can't believe this is how they are 'meant' to be considering they are supplied by MNR.
Shock
Shock
I know the brake line is in the way - it is getting shortened next week.
Lee
first350
posted on 25/5/11 at 04:50 PM Reply With Quote
Mine look very similar in the rear...while driving hard around corners (~0.9 G's), it doesn't seem to bottom out. However when I've hit descent bumps at speed, I'm pretty sure it's on the bump stops.
*My fronts are the opposite...when the car is on jack stands, the springs are not loose (the spring perch is all the way up so that the springs are firm, but no pre-load). When the car is on the ground, my front ride height is a bit too low (LCA is not parallel with the ground). I assume this is normal b/c my push-rods are at the minimum length...I planned to raise the front by extended the push-rods. Is it possible that the Front and Rear should be swapped??
-Peter
BigLee
posted on 25/5/11 at 05:07 PM Reply With Quote
Swapping the front and rear were my 1st thoughts but doesnt work. The rears are 2 inches longer and simply won't fit with the front rockers. I have extended the push rods by about an inch so far. Now the engine and fluids are in, it is almost there. Maybe another quarter inch.
I'll probably end up buying new shocks for the rear. Something that is correct for the job rather than driving on the bump stops!
Lee
lucy
posted on 28/5/11 at 10:59 PM Reply With Quote
Springs
Springs should not be loose on full droop for any situation and shouldn't be any need for helper springs with pushrod setup.
Adjust pushrods to achieve correct height.
One of the advantages of the pushrod setup is that you don't have to preload the spring to get the correct ride height unlike lesser manufactures.
Wind the single collar up until the spring is not loose and then adjust the pushrod.
Don't tell MNR but I've put softer springs front and rear for a more compliant ride on the road. Not all road surfaces are like race tracks. Much more compliant with 'normal' road conditions.
Lucy
spiderman
posted on 29/5/11 at 12:22 AM Reply With Quote
Shocks too long or springs too short, they should not drop away from the collar on full droop and twang when weight is reapplied, not a problem when jacked up, just surprising when reseating, however not good when on full droop when driving i.e. hump back bridge, and possibly dangerous!
Spider
bassett
posted on 29/5/11 at 11:07 AM Reply With Quote
Lucy what springs did you opt for and if you dont mind me asking how much and where from, thank.
Adam
BigLee
posted on 29/5/11 at 11:26 AM Reply With Quote
Lucy - thanks for the info. The front shocks on the push rods are fine. All adjusted and sitting firm. The problem lies with the rears. I wonder whether it is a recent thing or whether all MNR's have a dodgy rear setup.
Krismc
posted on 30/5/11 at 08:08 AM Reply With Quote
My Rears are set so Spring wound up around 15mm after spring contacts collar under droop to get desired ride height. it leaves me with 2-3inches of travel in rear suspension, doesnt hit bump stops, and never ride your bump stops even once or twice, it will cause damage!
My fronts can fit the larger shockers in, all apeared fine but after settling that left very little suspension travel (so dont do it!)
Ive got the shorter ones in now with heavier 250lb springs and im still concerned that under droop the rockers can hit chassis rails.
[Edited on 30/5/11 by Krismc]
marc n
posted on 31/5/11 at 07:53 AM Reply With Quote
hi lee
when car has settled, you will need to wind the springs back up to acheive your correct ride height, so will not have spring collar loose, ride height / travel when car is fully settled will be 1/3 travel in bump, 2/3rds travel in droop
cheers
marc
[Edited on 31/5/11 by marc n]
please email rather than u2u
chrismnrltd@btinternet.com
stevegough
posted on 31/5/11 at 08:07 AM Reply With Quote
Aye! +1 (Gaz shocks) allen key grub screw is in the single adjusting collar.
also +1 for the twang! on the rears as they regain their seating as they come off the jack.
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
lucy
posted on 31/5/11 at 07:44 PM Reply With Quote
springs and things
As marc n said; 1/3 travel in bump
2/3 travel in droop
Krismc - rockers hitting the chassis under droop! That can't be right. That isn't right. Would it help if the bolt on the top of the shocker was turned round? My bolt on the offside has been cut short to miss the tube.
stevegough - isn't right to have twang under any circumstances I would have thought.
bassett - for my bec setup I changed from 250lb x 8in and 150lb x 7in to 175lb x 9in and 125lb x 7in. £20 each approx
first350 - winding out the pushrods is the way to adjust for height. For my protech shocks the springs should be 5ins shorter than fully open length of the shock. ie 14in shock = 9in spring and 12in shock = 7in spring
Big Lee - as stated at the top, at the correct ride height the shocker pushrod should be 1/3 closed with 2/3 to go when hitting a bump ( without any spring slack at any point in the suspension travel). Sounds like shorter shocks would help. Are your springs loose at full droop when ride height is correct?
marc n - I'm struggling to see how the situation will be better when the suspension has settled. The shock length won't change and the spring may shorten making things worse not better (if there is slack in the spring at the moment, that will get worse, or am I missing something?)
ps I visited Protech for some work to be done on my shock. They wouldn't charge me!
I also bought my springs from them and they explained about the correct length spring for the particular shocks I had. Brilliant service.
pps I love my vortx.
daniel mason
posted on 31/5/11 at 07:53 PM Reply With Quote
^^^ have you bought my old car?
lucy
posted on 31/5/11 at 10:04 PM Reply With Quote
Not yours Dan. But I did see yours for sale some time ago( the blue one that is) I think.
Mines orange and a Busa. Built by ANother who did a cracking job. Left to me it would still be in kit form, waiting for more time than I've got. Too many hobbies etc
Krismc
posted on 1/6/11 at 05:29 AM Reply With Quote
Nope it'd the bolt head that hits chassis ,so unavoidable, I've mention a few times but I keep getting told its my setup, but either way it catches. Unless I preload the spring a lot more so that its more difficult, but still happens when I lift car up!!
lucy
posted on 1/6/11 at 09:51 AM Reply With Quote
Can MNR give you a clue as to what is wrong with your setup?
Which part of the rocker is hitting the chassis?
If it's hitting on full droop I presume the only thing you can adjust is the pushrod. The damper is the correct length I assume? Mine is 12in on the front for my bec. What length and poundage springs do you have?
<<  1    2  >>
