Author: Subject: megasuirt ouputs
Paul (Notts)
posted on 30/5/11 at 10:26 AM Reply With Quote
megasuirt ouputs
Just finish off the megasuirt installation.
I have 3 spare outputs that are switched earths. The manual shows them being used to activate relays and a 1amp fuse fitted to protect them.
Is the relay realy needed if I am only using them to light a 12v LED that only draws a current of 200mA max.
use to run megajolt outputs striaght to the leds to act as a shift light without the relays.
Paul
matt_gsxr
posted on 30/5/11 at 10:31 AM Reply With Quote
You can drive an normal LED no problem. As long as you have a 300Ohm series resistor it won't draw more than about 40-50mA.
Probably worth having the resistor on the megasquirt side of things, which will make it a bit more immune to accidental short-circuits.
