turnipfarmer
posted on 5/6/11 at 01:33 PM |
Will any Ford ECU work OK?
Hi, all...
Just can't seem to get a straight answer to this question, so any help appreciated...
I'm getting a new 2 litre Zetec blacktop & want to run the standard Ford ECU. Will any ECU from an old 2 litre blacktop run it OK, or are
there significant differences? If, so, which is the best one to get?
On-topic replies only, please.
Madinventions
posted on 5/6/11 at 01:47 PM |
big-wasa will be your man for this question... maybe worth a U2U?
View my band website:
http://www.shadowlight.org.uk
jollygreengiant
posted on 5/6/11 at 01:52 PM |
So long as its an ECU from an engine of the same type and capacity, then the answer should be yes. But the closer you can get to the engine donor age
and spec then the better.
RichardK
posted on 5/6/11 at 04:48 PM |
ECU off an auto is different mate for sure
Gallery updated 11/01/2011
AndyW
posted on 5/6/11 at 05:01 PM |
Im sure you need the ecu from the year of the engine, and yes the auto is different.
