andrew-theasby
posted on 22/7/04 at 03:15 AM |
citroen xm fuse box
Ive caused myself a slight problem now i acquired a citreon xm/bx or pug 309/405 (88-92) fuse box to base my wiring on as its a nice neat and
compact unit with all the relays in too. The only thing is i took all the fuses out to track all the circuits in it and now i dont know which fuses
go where so if any body has a hand book for one of these with a diagram in it, or sees one at their scrappy it'd be worth a few beer tokens to
me please as theres none im my local scrap yard. Thanks a lot, Andrew.
Staple balls
posted on 22/7/04 at 03:28 AM |
google kicked this up, couldn't find much on a quick flick through, but you might have more luck
clicky
Ben_Copeland
posted on 22/7/04 at 05:37 AM |
Pop into Halfords... the haynes manual "might" have them in....
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
hortimech
posted on 22/7/04 at 07:59 AM |
I have both a bx workshop manual and a bx,
but I would have thought that you would be changing the fuse rateings to suit your car/ circuits.
Why does everything happen to me
zilspeed
posted on 22/7/04 at 09:52 AM |
Citroen XM fusebox
I just had to try saying it again to see if the shiver was still there.
I owned an XM when they were still cool in a sort of defiantly non germanic way.
It was ok until it started to go all french and unreliable on me - I'm sure my car invented the hopping suspension found on lowriders. And it
was all caused by dodgy wiring - mostly centered on the suspension computer.
andrew-theasby
posted on 23/7/04 at 10:58 PM |
Its only the fuse box im using, hopefully my wiring wont be (as) dodgy I think ive sourced a mannual now off someone one ebay, but ill bear you in
mind hortimech if it falls through. Thanks for helping anyway everybody.
