Author: Subject: Rose Joints
MonkeyHunter
posted on 23/7/04 at 11:47 AM Reply With Quote
Rose Joints
Hi, What size rose joints have people used for their suspension? I am considering going rose jointed, so am wondering how meaty the joints need to be. Would
3/8 x 7/16 or 10mm/10mm (bore/thread)be up to the job if used to secure the wishbones to the chassis?
Cheers, Scott.
Terrapin_racing
posted on 23/7/04 at 12:17 PM Reply With Quote
size is not the only consideration - look at the specification - you can get a 3/8 SRE that will be rated at 3000lbs or one rated at 9900lbs - difference is cost.
see Nick for advice / bargain joints
N.Skidmore@wlv.ac.uk
Terrapin_racing
posted on 23/7/04 at 12:19 PM Reply With Quote
doc attached
derf
posted on 23/7/04 at 12:33 PM Reply With Quote
The ones I use are 5/8" rated at 5500 lbs, they were made to be used on circle dirt track cars.
MonkeyHunter
posted on 23/7/04 at 01:11 PM Reply With Quote
Thanks guys, ill do some more research i think.
craig1410
posted on 23/7/04 at 11:31 PM Reply With Quote
I used 1/2"x1/2" which I think were rated at around 7000lbs for my trailing arms. I will use stronger ones (still 1/2"x1/2" though) for my panhard rod due to the fact that a breakage of the panhard rod will be more of a safety concern than a breakage of a single trailing arm.
Also, get a right hand thread for one end and a left hand thread for the other. That way you can loosen the locknuts and simpl turn the bar to change the length.
Rally Design have a good selection of rod ends, mainly from National.
Craig.
