Author: Subject: Duratec crank position sensor wireing
mihau
posted on 4/7/11 at 10:23 AM Reply With Quote
I'm wiring my Duratec 2.0 and have a rady built loom from Omex.
The Crank Position Sensor plug on Omex loom does not mach the sensor on Duratec. I have the original plug but not sure I can dismantle it and rewire.
Can I cut and crimp/solder wires to CPS ? Or to risky ?
One more thing - do I realy need a CPS aligment tool or just make sure the gap between the sensor head and tooth wheel is 1mm ?
I'm waiting for answer from Omex to my problem (is it possible they messed the plugs ? )
Mihau
karlak
posted on 4/7/11 at 11:07 AM Reply With Quote
Hmmm, I would suggest they have put the wrong plug on it.
The "ready made" part of the loom implies that is should have the basic requirements to connect a to a Duratec. Let us know what they say.
[Edited on 4/7/11 by karlak]
MK Indy - 2litre Duratec - Omex 600 - Jenvey throttle bodies - ETB DigiDash2
mihau
posted on 4/7/11 at 11:37 AM Reply With Quote
They usualy reply fast, so will post an update. I was surprised too, as all other sensors and connetions were plug'n'play (almost - wiring diagrams on manual ar for semi-assmbled loom not the "ready" one - wiring of main realy is different, and fusing the ECU is not obvious).
mihau
mihau
posted on 4/7/11 at 01:31 PM Reply With Quote
and solved
answer from Alan from Omex :
"I am sorry that you have the wrong connector on your wiring loom. An adaptor to the correct connector will leave in the post today."
their great service is not a myth
Mihau
