kitcar007kev
posted on 12/7/11 at 07:39 PM |
Help with Mini
Advice needed
Advice needed - never stripped a car before. do i need to replace sills and floor or can i patch floor??
theconrodkid
posted on 12/7/11 at 07:51 PM |
when i was brave enough to tackle such things,you could buy extra wide sills that covered all the rusty floor pan area
who cares who wins
pass the pork pies
Ninehigh
posted on 12/7/11 at 07:52 PM |
Personally I'd replace them, however if someone more knowledgable says otherwise then fine.
The floor itself appears to be fine and small holes I reckon could be patched, but the sills look pretty bad
minitici
posted on 12/7/11 at 07:56 PM |
At least you have a rotisserie which makes working on the car a lot easier.
Just don't cut out all the floors and sills at the same time!
Just as well that Mini panels are readily available and cheap.
I've not looked at my Italian Job for a few years but I suspect that the bodywork has not improved with age
(Last time I looked, it needed front & rear valencies, windscreen scuttle, bonnet and door skins and probably needs yet another set of sills and A
panels)
russbost
posted on 12/7/11 at 08:49 PM |
Don't be tempted to just slap new sills over the rusted old metal. Cut all the rusty old stuff (not both sides at once!) away before welding new
panels on, you will probably find the inner sills have substantial rot as well. Some of the old patches only appear to have been tack welded in place
- any patch panels should be seam welded for MoT purposes, tack or spot welding is only acceptable for MoT where the panels were attached that way as
original. As said at least panels are cheap!
Kwik
posted on 12/7/11 at 08:55 PM |
replace sills, floor wise i would patch it, but panels are amazingly cheap you may as well replace it for a panel...
i restored a car in a bit of a worse state than yours, dont give up on it they are a joy to drive, especially when its something you restored...
noc231073
posted on 12/7/11 at 09:06 PM |
you need to remove the outer sills first to see what under neat...
then replace the rusty floor panels....you can buy quarter floor panels and patch with them
and put new sills on
is it for a z car build?
if so just repair up to the part you have to cut .
noc231073
posted on 12/7/11 at 09:12 PM |
oh btw can you weld ???
if not nows a good time to start learning ....
learnt my welding on a mini
from this
noc231073
posted on 12/7/11 at 09:14 PM |
to this :
and a front page on mini magazine...
and never welded before i started..
it can be done
[Edited on 12/7/11 by noc231073]
noc231073
posted on 12/7/11 at 09:19 PM |
if ya need any help dont be afraid to u2u me ...
Badger_McLetcher
posted on 12/7/11 at 10:19 PM |
I'd replace them personally, not doing so is a false economy IMO.
Where ya to mate? If you're relatively close I'd be happy to come have a butchers
If disfunction is a function, then I must be some kind of genius.
