jabbahutt
posted on 21/7/11 at 12:21 PM |
indicator pins on Sierra column
Afternoon
been a while since I consulted the locost brains for electrical info. Could anyone explain ( in laymans) whether the pins on the column for the
indicators (L- white/black for left & R-green/black for right) are these switched earths to the flasher relay or positives?
I'm thinking of fitting sparco style buttons instrad of using the indicator stalk and wondered whether the other terminal on each button should
be wired to a +'ve or a -'ve if the other contacts go to the pins above.
If anyone could explain (simply) the easiest way to do this I'd be very grateful.
Your patience as always is much appreciated
The electrical fool
Staple balls
posted on 21/7/11 at 04:47 PM |
Doesn't it depend which version of the stalks you have?
I seem to remember 83BGs are switched live, 87BG are switched earth.
But I could be backwards, wrong, or mad.
snowy2
posted on 23/7/11 at 06:26 AM |
i dont think that it matters as either type of switch can usually do both jobs.
sometimes you are the pigeon, most of the time the statue.
