ChrisLeary
posted on 26/7/11 at 08:10 AM |
Ignition Key
Morning all,
This may be a really quick and easy fix, but I'm not great with electronics. When I turn the key off in the ford ignition barrel it
doesn't cut the engine out...
Is this a wiring problem or is it something internal?
Any ideas?
Chris
flibble
posted on 26/7/11 at 08:45 AM |
Is your alterantor supply cut off via the ignition switch?
ChrisLeary
posted on 26/7/11 at 08:51 AM |
I'm not too sure, if I turn the key off, the dials drop to zero, but the engine won't stop running.
Thanks,
Chris
Chippy
posted on 26/7/11 at 01:20 PM |
I would say that it's definately a wiring fault, possably running on the alternator output. This needs to be cut when you turn off the ignition.
HTH Ray
