richardh
posted on 27/7/11 at 07:46 PM |
tin top tow bar wiring help needed
Hi, i've got a 55plate laguna estate and trying to follow fitting guide but it says there are 7 pins in rear cluster wiring but i've got 8
wires and only 6 pins (2 into 2 pins)
colours are so not obvious.
tried my circuit test light but guess must be for something more powerful as no light on it
googled around and can only find the 7 pin info
anyone know or got a similar setup?
i'm trying to scotchlock in temporarily before soldering the damn stuff on at weekend.
thanks
Time for a change!
doddy
posted on 27/7/11 at 07:56 PM |
this site may help
http://www.etrailer.com/faq-wiring.aspx
https://www.ebay.co.uk/str/4x4wheels
JAMSTER
posted on 27/7/11 at 08:00 PM |
you may need somthing like this. you will have be carefull because of canbus wiring
7Pin Spec towbar Wiring renault laguna Est 01 To 08 | eBay
[Edited on 27/7/11 by JAMSTER]
macc man
posted on 27/7/11 at 08:11 PM |
When I fit a tow bar I switch on the cicuits one at a time and identify the relavent wire. ie brake light or sidelight. The wiring kit usually gives
the wire coloursf or the plug. So all you need is to do is match them up. A wire strap will be needed for the indicator wire either ns or os. If you
are sruggling give me a u2u. I fitted one to my vectra recently so I may still have the info.
posted on 27/7/11 at 10:26 PM |
What are your 8 wires and what is your 6 pin socket? The standard 12n socket has 7 pins, have you got the rear hazard in there? There is probably no
provision for it.
[Edited on 27/7/11 by Peteff]
Ben_Copeland
posted on 28/7/11 at 06:18 AM |
Yep don't wire it directly to the lighting circuit. You need a special 7 way relay because of the bulb sensors on the peugeot. It won't be
able to understand the additional loads etc.
I have one on my van, which has bulb sensors. Bit of a pain but the relay works fine.
The 2 into 2 will be for splitting to brake lights either side.
[Edited on 28/7/11 by Ben_Copeland]
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
richardh
posted on 28/7/11 at 06:29 AM |
no bulb sensors on mine apparently so i just need to work out what is what
Time for a change!
Ben_Copeland
posted on 28/7/11 at 06:47 AM |
If your really stuck I'm off all next week if you want to pop down to margate. Don't several now so it's still fresh in my head
Ben
Roadster
ragindave
posted on 28/7/11 at 11:35 AM |
Tow Bar
Are you using a relay?
You find most later models work on a low voltage signal wires these you need to feed through a relay you can not feed trailer lights directly off the
vehicle wires on a lot of modern vehicles.
richardh
posted on 28/7/11 at 01:58 PM |
i checked the kit with towequipe before i got it and after i received it and was told would be ok
Time for a change!
richardh
posted on 28/7/11 at 05:23 PM |
kak, looks like there are so many options available.
Some say the relay bit is recommended, others say necessary.
but there are different variants of wiring kits too
rang the place but they not rung me back yet.
FFS why are car electrics so damn confusing these days?
low voltage this and that, it didn't take this long to rewire the entire old series landy i had.
Time for a change!
Ben_Copeland
posted on 28/7/11 at 07:20 PM |
Offers still open if need help.
What is it your actually stuck on now?
Ben
Roadster
richardh
posted on 29/7/11 at 08:14 AM |
u have u2u
Time for a change!
