Author: Subject: Speedo Healer Harness help needed.
wylliezx9r
posted on 9/9/11 at 11:27 AM Reply With Quote
Afternoon all,
I have bought a speedo healer V4 second hand. It came with the loom to fit a ZX12R engine but i am using a ZX9R engine. The connectors are exactly the same but the wiring must be different. I have swapped the wires around and have managed to power the unit up, but i cant get it to pick any reading up ( the speedo works without the speedo healer in circuit so no problems there).
Im just wondering if anybody could point me in the direction of a wiring diagram or such like so that i can configure the harness to work on my zx9r.
Any help gratefully appreciated
Dan
Just to add i have tried searching on here and google etc but have had no luck
[Edited on 9/9/11 by wylliezx9r]
George Best
CRAIGR
Contributor
Posts 2762
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 9/9/11 at 03:21 PM Reply With Quote
Seems you need an SH-K01 loom instead of an SH-K02 which does the zx12
http://www.healtech-electronics.com/
wylliezx9r
posted on 9/9/11 at 03:35 PM Reply With Quote
I realize that mate but surely the harness I have now can be modified it already has the correct connectors on it?
George Best
CRAIGR
Contributor
Posts 2762
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 9/9/11 at 03:53 PM Reply With Quote
U2u Dangle kt as he may be able to help if you read his post in this thread.
http://www.locostbuilders.co.uk/viewthread.php?tid=124238
mistergrumpy
posted on 9/9/11 at 04:52 PM Reply With Quote
Are you using the ZX9 clocks and/or loom and have you cut into the right wire? I have the prior Speedohealer which came without a harness and couldn't get mine to work. I'd cut the wrong colour wire.
wylliezx9r
posted on 9/9/11 at 05:28 PM Reply With Quote
Yes I am using the bike clocks. The harness I got with it splices between the sensor and the loom, there's no need to cut into the loom. Obviously being for a 12r the wiring is different. I may just have a go at pot luck and chance and change the wires around in the sub loom.
George Best
