Author: Subject: Headlight size
matlee
posted on 23/9/11 at 12:38 PM Reply With Quote
Headlight size
Ive read through the IVA manual regarding the lighting requirements but cant seem to find anything relating to the minimum dimensions for the headlights. So with that in mind does anybody know what, if there is one, the minimum size you can fit?
blakep82
posted on 23/9/11 at 12:46 PM Reply With Quote
best bet, to be sure, find some that are e-marked. i got the 90mm hella ones (though you'd struggle to mount them on a 7 i think)
russ bost sells smaller ones i think. 80mm? emarked too.
e marking will ensure they're fine
________________________
russbost
posted on 23/9/11 at 12:56 PM Reply With Quote
My smallest ones are 50mm across the lenses, twin units, look crackibng on a 7, got some 38mm ones (chassis units) coming shortly, all are E marked, but TBH E marking is irrelevant for IVA (only exception is fog light which must be E marked) all they are interested in at IVA is do the headlamps throw the correct beam pattern & for all other lights do they meet the angle of view/position requirements & are they of suitable brightness.
Russ
matlee
posted on 23/9/11 at 01:15 PM Reply With Quote
Thanks for the replies guys, they were the answers i was hoping for! Didint really fancy lights the size of saucepans
Going very slightly off topic here guys but do you know where i can source some rear light holders/pods. All i can find is the type that need to fixed to a flate surface where as the sort i want is a 2/3 fixed vertically stacked type with one horizontal fixing point, as in my very detailed illustration below
O
O---[
O
