whitstella
posted on 6/10/11 at 06:43 PM |
wiring my MK
hi
i was just wondring if there are any local people/person that is good with car wirirng as i dont know where to start. i'm willing to pay but i
cannot find any auto elec that is that intrested. eddie99 has offered but he is miles away and its costly when you add fuel cost to digs for a
night.
or can anyone recommend a company or person to do the job.
cheers steve
vyperstrype
posted on 6/10/11 at 08:15 PM |
MK Wiring
Are you wiring from scratch? Or, do you have a Vicky Green Loom? When i did mine a few years back, i used a vicky Green wiring loom of which the
diagram is quite easy to follow. Also you should be able to download the diagram off the net, or if you ask somebody on here nicely they will post a
link on here.
Cheers Eric.
Where there's a will, there's a death!!
whitstella
posted on 6/10/11 at 08:25 PM |
hi
this is where its been made difficult, i brought the kit part done with most parts. its got a elise engine, ecu, loom and dash so with the loom sat in
a heap on top of the engine it looks a mess and i dont know where to begin. using a new loom might be the way to go but i would still need some
help.
cheers
big-vee-twin
posted on 6/10/11 at 09:41 PM |
My advice would be to buy a Premier wiring, loom and start again.
The Premier wiring loom is high quality and very easy to install with step by step instructions.
http://www.triangleltd.com
austin man
posted on 6/10/11 at 10:27 PM |
you will still need to splice the Elise loom in to run the clocks and ecu so would need the Elise wiring diagram as well
RK
posted on 7/10/11 at 12:45 PM |
Do you have Elise clocks? If so, I seem to remember something about them that makes them very hard to get going properly (I have no experience with
them specifically). If you absolutely must have those instruments, I think you will be in for a long road here. Make things as easy as you can, and if
it means selling Elise clocks and loom to do it, just move on and finish building your car. I am certain you are not the first to cross this bridge
and live to tell the tale.
