mattv6cosworth
posted on 23/10/11 at 11:19 AM |
starter diagram
hi bought the car in my pictures as a none runner the car turns over but theres no spark at the plugs. the wiring is totaly screwed theres bits all
over the place. has any one got a basic starting diagram or know the best place to get one from. its a 1.6 pinto not sure what year though cheers
posted on 23/10/11 at 05:27 PM |
It depends which distributor and ignition system it has to which diagram it needs. Your best bet is to get an old Sierra Haynes manual.
snowy2
posted on 23/10/11 at 06:14 PM |
if it is points ignition all you need to do is run a live wire to the +ve terminal of the coil and connect the -ve terminal to the distributor, if it
is getting fuel it will fire.
sometimes you are the pigeon, most of the time the statue.
