Author: Subject: What Type 9 ratios have I got?
Jason Fletcher
posted on 21/11/11 at 11:14 PM Reply With Quote
The metal tag has the following on it
839T NF
F0G 7K 08G
anyone know?
thanks
Jason
[Edited on 21/11/11 by Jason Fletcher]
snapper
posted on 22/11/11 at 06:45 AM Reply With Quote
I have not found any list quoting casting numbers on a type 9 casing that relate to gear ratios.
I have seen an article that quotes tooth count to ratio.
You take the top cover off and count teeth, the chart then tells you what ratios you have.
Retro ford mag back issue I thing, found a digital copy on the web.
I eat to survive
I drink to forget
MakeEverything
posted on 22/11/11 at 08:28 AM Reply With Quote
Ive seen a list on the net somewhere, from a classic car forum i think. Sorry, not much help, only hope.
Kindest Regards,
Richard.
Surrey Dave
posted on 22/11/11 at 09:58 AM Reply With Quote
Mountain goat!
Like most of us you probably have a 1st gear that is only suitable for climbing up mountains !
I nearly always pull away in 2nd.
Gary 7
posted on 22/11/11 at 02:32 PM Reply With Quote
If you remove the lid and count the teeth on the input shaft ,this will tell you the ratio. 19 tooth and a long input shaft 2.8
ratio. 18 tooth short input is 1.6/1.8/2.0 / 18 tooth long input is diesel type 9. I cant remember if the 2.3 box has a long
or short input but will be 18 tooth same ratios as 1.3-2.0 . try the link below
http://www.eddybrown.co.uk/mg/wp-content/uploads/2008/07/type9.pdf
[Edited on 22/11/11 by Gary 7]
Dingz
posted on 22/11/11 at 07:46 PM Reply With Quote
I think the std. box ratios are 3.65, 1.97,1.36,1, 0.82
V6 box 3.36, 1.81, 1.26, 1, 0.882.
went on and on.
Paul Turner
posted on 22/11/11 at 08:24 PM Reply With Quote
2.3 V6 had standard ratios with a diesel input shaft, Mr Ford is clever like that.
Just pray you don't have a diesel box, they have horrid ratios.
