ernie
posted on 8/12/11 at 05:58 PM |
2012 regs
Bleeding brilliant!!
just bought new set of headlights, (driving lights) just to be told not needed in 2012
PANDE FIRE & SECURITY SYSTEMS
eddie99
posted on 8/12/11 at 05:59 PM |
Dont get me started on the 750MC regs.... They've completely successfully screwed up Bikesports ![](/images//smilies/sad.gif)
Stott
posted on 8/12/11 at 09:41 PM |
Could be worse, night event regs changed a few years ago so you could only have 4 forward facing lamps cos of "light pollution" and all
the boys had pods full of HIDs at about £700 a pop all in that they could no longer use.
Plus all the BMW e30s have 4 lamps as STD as they are separate units, but if you had an e36 or any other car with STD covered 1 piece headlamps you
could also run spots.
Regs suck
MK9R
posted on 8/12/11 at 11:25 PM |
What's happened then?
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
eddie99
posted on 8/12/11 at 11:26 PM |
Min Weight 50kg above what we were, we were aiming for another 30kg, so that'll be 80kg of weight somewhere to add in....
Oh and apparently we're not allowed to adjust any chassis or suspension pickup points, only as per original manufactures car. Therefore our car
being entered next year will be our own new car
[Edited on 8/12/11 by eddie99]
MK9R
posted on 8/12/11 at 11:30 PM |
What's the reason for that then?
Cheers Austen
RGB car number 9
www.trackace.co.uk
eddie99
posted on 8/12/11 at 11:33 PM |
No Idea, im hoping to get an answer, And some other silly rules with engines, such as there is no room for a 1ltr tuned engine but you can do whatever
you want with a busa... Meaning no room for a certain radical along the lines...
Oh and only 5 weekends with 10 races, 4 races at donny! Cant complain that donny isnt a great track however to have 40% of your championship at one
place seems a bit much!
steveiow
posted on 9/12/11 at 08:41 AM |
As far as Locost are concerned, I think its a great improvement to the calendar. To have to travel from where I am is bad enough, but to do it to
say, Cadwell, for one race is a mission. I love the double header race weekends. Means I may be able to fit in some sprints and autotests in
between.
As for regs for Locost, allowing removal of all front lights is a good thing in my opinion. The other minor changes I need to look into more
closely.
What I would like to see is the TV coverage back. I note from the minutes of committee as printed in the Bulletin that race fixtures were set taking
into account the results of the driver survey, so be interesting to see what the entry fees will be and if they do include extra cost to cover the TV
company, which was also questioned in the same survey.
2012 Locost Race Car #12 - for everything Locost Racing: www.SEWC.co.uk
procomp
posted on 9/12/11 at 04:05 PM |
Hi
The removal of the front lights from the Locosts has been talked about for the last 3-4 years. However don't get rid off them Ernie you may want
to quickly refit them at some point such as a wet race meeting. That's why it's an option to remove them. Will however save many people
having to replace them every other race due to stone damage.
Cheers Matt
steveiow
posted on 9/12/11 at 04:11 PM |
I presume its not an MSA requirement to run lights on the front in the rain, so if you arent fussed about running them, you could remove them
permanently?
procomp
posted on 9/12/11 at 04:47 PM |
Hi
The MSA regulation that is referred to in the regs allows us to run without them permanently. But have been left as optional for those who wish to run
with them in the wet or any conditions.
Cheers Matt
ernie
posted on 9/12/11 at 04:59 PM |
yes, I did think they were quite necessary at Cadwell
ShaunB
posted on 9/12/11 at 06:30 PM |
Mallory too, even when testing at Silverstone this year some cars just suddenly appeared out of the spray whereas the ones running lights were far
easier to spot.
By good fortune I made my Locost headlight brackets removable earlier this year, each side is now held on by 4 bolts into rivnuts in the chassis tubes
(the holes were already there as the previous owner had mounted the brackets with rivets).
Shaun.
pointy
posted on 9/12/11 at 07:07 PM |
Perhaps I'm on my own on this one but removing the lights and front indicators albeit optional is the start of turning the locost into a mini
Caterham, I mean what will be the next change, slick tyres, a different cam, twin 40 carbs...then a different engine with an ECU, no, I'm afraid
I am not happy about the change and the ethos of Locost is being slowly eroded.
Andy P
Halemini
posted on 14/12/11 at 09:05 PM |
Front suspension pick up to be located as per section 6 diagram 3 - which doesn't exist!! Can anyone explain?
Rgds Dc
modee
posted on 14/12/11 at 09:15 PM |
Halemini. The suspension pick-up diagram is on page 10 of the online regs. You need to turn the page (or your head) through 90 degrees to make sense
of it. Maurice
Halemini
posted on 14/12/11 at 09:28 PM |
Thanks modee, On page 10 there is one diagram showing the rear suspension? Nothing else! Is my iPad playing up? Is it meant to be the same diagram as
last year?
modee
posted on 14/12/11 at 11:02 PM |
Halemini. There should be 3 diagrams on page 10. Maurice
Halemini
posted on 15/12/11 at 10:51 AM |
I checked again this morning on a real computer and it's all there! So it was a technical problem - Apologies!
Thanks again
Dc
spoonana
posted on 28/12/11 at 01:05 PM |
Andy P
I think the real ethos of locost is that it is LOW COST. I can understand the reason they are allowing you to remove the lights if they keep getting
damaged, to lower costs. One day we will run out of xflow engines and a modern day replacement will have to be used.
What I don't understand is if you are allowed to remove your lights, why do they still have to be 5 3/4" if you decide to keep them on??
locost47
posted on 2/1/12 at 05:23 PM |
locost 2012 dates
do the rear indicators need to flash obviously if so whats the best way round this lights inside some were or side mounts ![](/images//smilies/smile.gif)
spoonana
posted on 2/1/12 at 05:31 PM |
I have them side mounted just above the arches.
![](http://img849.imageshack.us/img849/3753/20111230153540.jpg)
ShaunB
posted on 2/1/12 at 06:06 PM |
Hi Tim, I mailed the club earlier today to clarify whether they still need to flash at the correct speed, I'll let you know their response. If
they say yes I can see 2 ways round it, add a suitable load to the front indicator wiring either wire a couple of indicator bulbs in or use
equivalent resistors, alternatively swap the
flasher relay for one that is not load sensitive.
Shaun.
steveiow
posted on 2/1/12 at 06:14 PM |
I love the 1:1 scale of your photo Max
locost47
posted on 2/1/12 at 06:52 PM |
locost
cheers shaun look forward to reply
