Author: Subject: megasquirt wire size
gavin174
posted on 3/1/12 at 09:21 PM Reply With Quote
Evening all I have bought a second hand megasquirt EFi
which is designed to be plug and play to replace the original ford ECU
I want to remove the ecu part of it and make it a standard megaquirt..
can anyone tell me what diameter/amp cable I should use please
Thanks in Advance
Gavin
snapper
posted on 4/1/12 at 08:05 AM Reply With Quote
Most of the cable is low power, standard cable fine, check requirements but I think power in is rated at 7amps very light
Any doubt match the leads from the squirt to the ford ecu plug
VR sensor should be shielded, I have some.
I eat to survive
I drink to forget
ashg
posted on 4/1/12 at 09:03 AM Reply With Quote
max output is 10 amp on the injector and ignition wires. the rest can all be thin as they are virtually all signal wires.
on my car i used 16.5amp 1mm thin wall cable for the injectors and ignition the rest i just used 11amp 0.5mm thin wall.
http://www.vehicle-wiring-products.eu/VWP-onlinestore/cable/thinwall.php
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
big-vee-twin
posted on 4/1/12 at 09:04 AM Reply With Quote
Just built a MS loom.
You should use 0.5mm thin wall cable for all of the wiring, except for the injectors and coil which uses 1.0mm thin wall cable.
The injectors and coil take more current.
I can email you a spread sheet with the wiring loom details, colours where they connect and size if you U2U me your email.
[Edited on 4/1/12 by big-vee-twin]
http://www.triangleltd.com
matt_gsxr
posted on 4/1/12 at 11:30 AM Reply With Quote
needs a decent earth too as lots of the current goes that way.
gavin174
posted on 4/1/12 at 12:33 PM Reply With Quote
Any details you have would be great
I have printed off an Autosports diagram I found on here,
but its not making much sense.
