Gear Monkey
posted on 4/1/12 at 01:38 AM |
Minimum legal dash display requirements
I'll be starting my build in the next week and therefore in the planning stages of the finer details. I intend to go down a minimalistic route
and have nothing more than a start button, ignition switch and a custom made digital read out showing RPM, MPH and Engine Temp. Other controls will be
lights indicators and horn.
Have I missed anything out that's a legal requirement?
Many thanks
Paul
snapper
posted on 4/1/12 at 07:52 AM |
Hazard warning light
Handbrake light which doubles as fluid level warning
Main beam warning
Indicators
fog light warning could be incorporated in the switch
I eat to survive
I drink to forget
adithorp
posted on 4/1/12 at 08:26 AM |
Minimum dash requirements are...
Speedo (in MPH) with illumination, Must be perminently displayed (beware of having any buttons that allow you to switch to some other display).
Indicator repeaters.
Hazard warning repeater (can be combined with indicators repeaters)
Rear fog warning. Must be red with correct symbol on the illuminated surface.
Main beam warning.
Brake fluid level warning with the correct symbol. Has to be testable from the driving position so is usually combined with a handbrake light (which
in itself isn't a requirement).
Plus switches for everything.
Identification on all switches. Hazard warning switch must illuminate when side lights on.
In addition you might need...
Reverse warning light if not automaticaly switched.
Side light warning. Usually the speedo illumination so if it's perminently illuminated you need another warning light.
http://jpsc.org.uk/forum/
mad-butcher
posted on 4/1/12 at 09:38 AM |
All requirements can be more or less met in any Acewell unit, contact russbost on here for a good deal, other makes of dashes are availiable else
were
tony
loggyboy
posted on 4/1/12 at 09:40 AM |
Indicators could be a buzzer, or none at all if you can see the front indicators.
quote: There must be a audible or visual tell tale fitted to indicate the operation of any indicators such that would not cause confusion to the
driver (see note 1)
The hazard warning device must have a telltale warning light (see note 1)
Note 1: A tell tale is not required if the front indicators are directly clearly visible to the driver
Brake fluid warning light can be dropped if you have a fluid reservior that you can see the fluid level through without removing the cap. (needs a min
level marker too)
However, you still need a light to satisfy the need to have a warning light if pressure drops on the hydraulic system/or have a fluid level warning
light - so its usuaally considered easier to retain the fluid level warning light!
quote: It must be possible to check the fluid relative to the manufacturer’s specified minimum level on all brake fluid reservoirs by the actual fluid
level being visible through a transparent section of the reservoir, with the minimum level marked permanently on to this section. As an alternative, a
red warning lamp (see figure 1) must be capable of illuminating when the reservoir fluid falls to the minimum level.
The hydraulic system must be fitted with a red warning lamp, sensitive to line pressure and capable of signalling the failure of any part of the
hydraulic system as soon as the brake is applied and remaining lit as long as the failure exists (with the ignition switched on). As an alternative,
the warning lamp must be sensitive to the reservoir fluid level, providing the reservoir is directly connected to supply the pressure side of the
master cylinder when the piston is in the “brakes off” position, so that a failure of either part of a split system would result in a continuous
draining of the reservoir fluid when the control is released (see note 2 and 3).
Fog warning can be any colour, as long as its clear, and can be a pictogram rather than a light. (not sure what that is?! something from the classic
era)
quote: Either the switch or tell tale must clearly indicate that operation relates to the Rear Fog lights (see Note 1).
Note 1: This may be achieved by an unlit pictogram (see section 33) or appropriate words, the tell tale may be any colour provided it cannot be
confused with any other tell tale.
[Edited on 4/1/12 by loggyboy]
Gear Monkey
posted on 4/1/12 at 01:18 PM |
Thanks for all the help chaps, this forum is an absolute gold mine of info, much appreciated.
An acewell unit at £200 looks to be a tidy, lightweight and stylish solution and it's perfect for the look i'm going for.
Thanks again
GM
mad-butcher
posted on 4/1/12 at 04:24 PM |
As I said if you contact russbost on the forum as a supplier of Acewell units he will give you all the info you require
tony
Gear Monkey
posted on 4/1/12 at 04:39 PM |
Having looked at the Acewell pdf I've come up with what I think is an awesome idea that will create a neat, functional and lightweight solution
to accompany the all in one digital dash.
Picture this.....Just behind the steering wheel to the left an short aluminium bar holding one of the Acewell motorcycle switch gear clusters. These
include controls for:
Lights (side/dipped/mail)
Horn
Indicators
Starter
Hazzards
And I'm guessing it's pretty much plug and play with the digital display. How cool would that be!!!
daniel mason
posted on 4/1/12 at 06:44 PM |
far from plug and play mate. they can be a pain to set up correctly!
