l0rd
posted on 7/1/12 at 03:40 PM |
H7 and H11 plugs
I am looking into converting to HIDs.
I noticed that the kits do not have an adaptor for the car loom and just have the wire with a spade connector.
Where would i be able to find some plugs so i can make it neatier if i go down this route?
TA
HowardB
posted on 7/1/12 at 07:58 PM |
this might not be significant but,....
HID lamps use a gas discharge system and require a ballast, igniter and a special high voltage circuit
They have two electrodes in a glass tube filled with Xenon gas and metal salts. When the high voltage is applied the electrodes form an arc which
ionizes the xenon atoms and metallic salts creating light.
HID lights are up to three times brighter than normal bulbs and therefore have the potential to dazzle other drivers. To combat this new vehicles
fitted with HID lighting must have either a headlamp levelling or rear suspension levelling system and a headlamp washing system.
Previously aftermarket kits were excluded from this requirement. However the DOT considers that after market kits should meet the same safety
requirements
Therefore effective 31st December 2011 in order to pass the MOT test ALL vehicles fitted with aftermarket HID lights will also need to be fitted with
a headlamp cleaning and levelling system
These systems are also mandatory for ALL vehicles fitted with LED headlights.
this is the situation as I understand it,...
hth
Howard
Ben_Copeland
posted on 7/1/12 at 08:09 PM |
Lives in Greece,dont think that applies....
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
Mark Allanson
posted on 7/1/12 at 08:23 PM |
At the moment, I don't this much of anything applies in Greece
HowardB
posted on 7/1/12 at 08:35 PM |
doh, didn't read that!
ignore all previous unless you are subject to UK MOTs
Howard
Ben_Copeland
posted on 7/1/12 at 09:48 PM |
ebay i'm guessing?
Could u not just cut the wires and solder them together?
Ben
Roadster
l0rd
posted on 7/1/12 at 10:15 PM |
ebay i'm guessing?
don't want to do a bodge job.
l0rd
posted on 7/1/12 at 10:23 PM |
At this point, getting F**ked by the politicians
NOPE it doesn't matter and to be honnest, i do not care any more.
I am paying taxes more than i should be, I am unemployed and they want me to pay £2000 on taxes so they can steal the money.
Anyone remember the Greek's primeminister declaration to go on a referendum? There was such a mess in Europe that all FInancial Markets
dropped.
How come the prime minister's brother made billions in the company he works for? Did he know about it before it happened?
