Author: Subject: Cutting a D shape advice please
John Bonnett
posted on 12/1/12 at 05:04 PM Reply With Quote
I need to make a hole with a flat on it to suit an ignition switch. In the past, I've drilled a round hole undersize and then filed it to shape.
I just wondered if anyone has a demon way of dealing with this.
John
loggyboy
posted on 12/1/12 at 05:05 PM Reply With Quote
How bigger a radius/diameter?
John Bonnett
posted on 12/1/12 at 05:21 PM Reply With Quote
I've not measured it exactly but about 19mm diam
[Edited on 12/1/12 by John Bonnett]
loggyboy
posted on 12/1/12 at 05:30 PM Reply With Quote
I would expect your method metioned is the most straight forward.
Its not like its big enough to use a jigsaw on.
LoMoss
posted on 12/1/12 at 05:53 PM Reply With Quote
Something like the q-max?
bit pricey d hole cutter
HTH
Moss
John Bonnett
posted on 12/1/12 at 06:26 PM Reply With Quote
HTH
Moss
That'd do it
loggyboy
posted on 12/1/12 at 06:38 PM Reply With Quote
at that price i would hope it would do a lot more besides!
contaminated
posted on 12/1/12 at 07:29 PM Reply With Quote
Me too - like wash my pants and bring up my kids!
Tiger Super Six Independent
www.southernkitcars.com
907
posted on 12/1/12 at 08:48 PM Reply With Quote
Hi John,
For such awkward shaped holes I have been known to make a template for my nibbler.
Cut the circle, chop off the flat, and tack a bit on to the remainder of the circle.
For cutting i/d's the template has to be bigger, and o/d's smaller. The amount will depend
on the size of the nibbler head.
What follows falls into two distinct categories.
1. Next time I need to cut a similar hole I can't find the template,
or
2. I never need to cut this shape hole ever again.
Paul G
John Bonnett
posted on 13/1/12 at 07:24 AM Reply With Quote
Thank you Paul. It's only a small hole, too small to be able to use a nibbler I would have thought so I'll do it as before.
Best regards
John
PS I've just started the GT6; first time it's run since 1989. It was music to my ears and I had to take a few seconds of video.
http://www.youtube.com/watch?v=PgKkCJ8ee-k
