JimM
posted on 21/1/12 at 12:38 PM |
Front Arches
Looking for help on how to secure the front arches to the wheel brackets.
Proby
posted on 21/1/12 at 12:58 PM |
Easiest way has to be to stick/bond them onto the brackets using silkaflex or similar.
tomgregory2000
posted on 21/1/12 at 01:20 PM |
wot he said ^^^^^^^^^^^^
Chippy
posted on 21/1/12 at 05:13 PM |
I used Evostics "Sticks Like S++t" and once set glassed over the brackets, absolutely no chance of it coming off then. HTH Ray
posted on 21/1/12 at 07:07 PM |
Bend some 25x 3 mm strip to fit the shape of the inner arch , Drill and tap a 6mm hole in the center , fit to the wheel arch brackets and the clean
the inside of the arch , cover the strip with a good dose of Sikaflex and place the arch in place , use clamps and leave for 24 hrs. Worked with my
original fibre glass archs but not with carbon fibre
Thurbs
posted on 21/1/12 at 07:23 PM |
Used tiger seal they've not come off yet !!
Dave Bailey
posted on 22/1/12 at 01:59 AM |
I made some ally brackets (Z cross sectio) that I glassed to the inside of the arch. Then drilled and tapped the support and screwd the arch to it..
If I need to replace the arch I just unscrew it.
Not driven it yet so don't know if they will stay on but I have walked into them enough times and my shins came off second best.
Dave B
stevegough
posted on 22/1/12 at 09:03 AM |
Another vote for Tigerseal - incredible sticking power, they haven't pulled off at 120 mph yet! I also coated the inside of the arches with
CBS's own 'wunderseal' - it is supposed to prevent internal stone chipping - I suppose it does, as it is a rubberry texture.
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
killieaitken
posted on 6/2/12 at 03:38 PM |
I actually bought a set that were already pre drilled and they bolted straight on
