DixieTheKid
posted on 28/1/12 at 01:29 PM |
Air Compressors
Hi all,
Looking for some info in air compressors, i dont own one but want to so i guess im after some buying tips. I found this one one ebay that looks
cheap.
AIR COMPRESSOR 200 LTR NEW c/w WARRANTY | eBay
Regards Chris
[Edited on 28/1/12 by DixieTheKid]
COS IT'S Worth IT
slingshot2000
posted on 28/1/12 at 01:36 PM |
The description is a little vague;
VOLTS 240
and two line down
POWER 3PH 2200WATT
I think I would be asking exactly what electrical supply is required, unless you have a 3 phase supply.
Regards
Jon
AndyW
posted on 28/1/12 at 01:42 PM |
VOLTS 240
and two line down
POWER 3PH 2200WATT
Regards
Jon
two lines down does it not say 3HP 2200WATT? I would assume its a 3 HORSE POWER 2200 WATT
you can also see the 3 pin power plug in the picture
DixieTheKid
posted on 28/1/12 at 01:44 PM |
I want to be able to spray with it, as well as using impact guns etc. I am told 200l is a good size, would you agree?
COS IT'S Worth IT
fazerruss
posted on 28/1/12 at 01:47 PM |
VOLTS 240
and two line down
POWER 3PH 2200WATT
Regards
Jon
No it says 3hp (3 horse power) not 3ph (3 phase) and there is 750w to an horse so 2200w is about right.
i wouldnt go for a 200 litre tank with that size pump and motor as it will take forever to reach a decent working pressure.
Ideally that compressor would suit a 50 litre tank which is good for most jobs.
"if assholes could fly this place would be an airport"
DixieTheKid
posted on 28/1/12 at 01:49 PM |
Ok so may be 200L is to big from me. See i dont know anything about pump and motor sizes vs tank size. What should i be looking for?
COS IT'S Worth IT
fazerruss
posted on 28/1/12 at 01:58 PM |
Ive had a clarke airmaster for nearly 20 years. 3hp motor,14cfm and 50 litre tank. It does all the jobs you list no probs.
I would run it off a 30amp supply cause the start up current on any single phase compressor can trip the fuse.
theconrodkid
posted on 28/1/12 at 02:02 PM |
BURISCH Air compressor 2.5HP 50L Upright vertical 50 litre 220v | eBay
takes up less floor space and has TUV
who cares who wins
pass the pork pies
big_wasa
posted on 28/1/12 at 02:05 PM |
50L + and 3hp is where you want to be. Mine is 100L and 3hp and the only thing it finds hard going is sand blasting.
fazerruss
posted on 28/1/12 at 02:19 PM |
Heres mine
![](/galpreviews/3P1010063.JPG) ![Description](/gallery/3P1010063.JPG) Description
and it runs the sand blast cabinet aswell.
I wouldnt recomend clarke now though cos its all the same shite made in china with a different sticker and an inflated price from machine mart.
bonzoronnie
posted on 28/1/12 at 02:35 PM |
I have just bought one of these Burich compressors
BURISCH Air Compressor 3HP 90L Belt Drive Twin 14CFM Twin Cylinder | eBay
Arrived next day & I am delighted with the quality & performance
I needed a replacement for my tiny portable as I seldom find it worthwhile firing up the big boy that lives up in the shed
Looking at the similar Machine Mart offering they look to be almost identical as the Burisch but cost nearly double the money ![](/images//smilies/shocked.gif)
slingshot2000
posted on 28/1/12 at 02:40 PM |
VOLTS 240
and two line down
POWER 3PH 2200WATT
Regards
Jon
Whoops, my mistake ! ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
DixieTheKid
posted on 28/1/12 at 02:58 PM |
That looks a good option! Thanks.
COS IT'S Worth IT
sdh2903
posted on 28/1/12 at 03:18 PM |
Hi, I got a 100L sealey 3hp compressor from this guy on ebay:
http://stores.ebay.co.uk/Recontooling-for-nearly-new-Sealey?_rdc=1
I got a red version of the black one he has listed which has a slightly higher output for around 190 delivered and its been great so far.
I've had a few things from him now and if your after something specific that isn't listed just drop him a message and he will see what he
can do. A really helpful bloke.
steve
Bare
posted on 28/1/12 at 07:07 PM |
Critical Spec on Any compressor is the CFM at a specific pressure. No CFM rating = No Buy :-)
IMO you need 4/6 cfm at 90 psi for light (typical) DIY work and 17 to 23 CFM for ANY sandblasting cabinet..
Unless you want to be at it for the entire day.
Duty cycles etc are another real consideration But the CFM is foremost.
[Edited on 28/1/12 by Bare]
bonzoronnie
posted on 28/1/12 at 07:31 PM |
CFM is only a measurement of how much air a compressor will shift over a given period of time ( Cubic Feet per Min )
Might be able to shift a lot of air but CFM not a true indication of how well the compressor performs.
A true guide of a compressors ability is its FAD output ( Free Air Delivery )
Loads of manufacturers of non industrial compressors do not reveal the FAD output of their products.
All that aside, the Burisch compressor will provide enough air to power rattle guns, spray guns & the likes . ![](/images//smilies/smile.gif)
