maccavvy
posted on 18/2/12 at 05:55 PM |
Wiring help needed
Ive got a robin hood 2b.
Used to have escort clocks fitted.
Just started today wiring the new dash set up in.
Got most of it working fine.
Oil pressure ,fuel gauge,water temp and all lighting fine
Not got rev counter fitted yet so dont know there yet
Indicator and main beam warning lights work fine.
But oil pressure lamp dont light up and battery light only comes on when its revved,when 1st fired up on tick over its out
The dash is all etb gauges with seperate round warning lamps,with all new senders.
Not checked the bulb in the oil yet as its too dark now but will tommorrow
Any ideas what to check 1st ?
designer
posted on 18/2/12 at 06:21 PM |
Wire and check each circuit in turn is the simplest way.
RK
posted on 19/2/12 at 01:10 AM |
Are they wired in series? If so, this should not happen. If not, I suspect a bad earth. It is a cliche perhaps, but I have found it is at least 99% of
all my electrical issues I've ever had. Wires can come loose after a lot of fiddling - especially if they are crimped and not soldered. Just
speaking from hard earned experience!!
snapper
posted on 19/2/12 at 05:19 AM |
Correct me if I'm wrong but the oil light runs of an oil pressure switch not an oil pressure sender and switches earth.
So +12V to the bulb, other side to the pressure switch as it has one terminal which earths through the block
I eat to survive
I drink to forget
maccavvy
posted on 19/2/12 at 07:48 AM |
Ah i think you may be right there snapper on the oil pressure switch.
silly me. thats easy to swap over thank god.
