beaver34
posted on 19/2/12 at 07:27 PM |
alternator belt clearance
im going to run another smaller alternator and ive been plying with where it is going to fit on the engine, now the question i have is how much belt
clearance do you need? i presume this is not enough???
Daddylonglegs
posted on 19/2/12 at 07:33 PM |
Bearing in mind the amount that belts can 'flap' on overrun, I would think it is a bit too close chap
DH2
posted on 19/2/12 at 09:21 PM |
You sure you're running the water pump in the correct direction?
I could swear mine runs the other way...
Is it too toasty on the other side to put the alternator there?
I want to change mine to exhaust side but water pump rotation is an issue.
blakep82
posted on 19/2/12 at 10:14 PM |
its a bit close, but say an extra 5mm length on the belt should see the alternator push out enough to give clearance perhaps?
________________________
beaver34
posted on 19/2/12 at 10:15 PM |
Come to think of it I'm not! Am I right or wrong?
Did want it on the other side but colum and exhaust stop that
SteveWalker
posted on 19/2/12 at 10:27 PM |
I don't know what engine that is - I'm not up on my engine recognition. However, I have read about some engines that have two different
water pumps depending on the original installation and that they rotate opposite ways. Mondeo Zetecs having pumps replaced with Escort/Orion pumps,
due to differing belt paths that can be used.
daviep
posted on 19/2/12 at 11:18 PM |
Have you thought about running the belt a different route?
Would this work? New route in red, obviously can't see whether there are any obstructions between the crank and the top idler
[img][/img]
Has the advantage that theer is more contact on the alternator.
Davie
Madinventions
posted on 20/2/12 at 12:06 AM |
Here's the standard routing in case it helps. Davie's suggested routing looks like pretty sensible for your setup.
Zetec SE engine belt
Ed.
View my band website:
http://www.shadowlight.org.uk
beaver34
posted on 20/2/12 at 06:19 AM |
thanks guys, good job i checked!
daves idea should work fine i think,
owelly
posted on 20/2/12 at 08:38 AM |
But then the water pump will be running the other way. Was there a different type engine that used the same pump but running the other way?
http://www.ppcmag.co.uk
daviep
posted on 20/2/12 at 09:23 AM |
Would you like a moment to re-consider this?
It's still going the same way because although the belt is on the opposite side of the water pump pulley it's being driven by the other
side of the crank pulley.
Davie
owelly
posted on 20/2/12 at 09:32 AM |
Yeah, I retract my last statement......... I won't edit it though so daviep looks mad.
