mazie
| posted on 11/3/12 at 05:31 PM |
Fitting hella mix and match lights
Hi all, I know this has been covered in some way before but I need anyone with close up photos of the hella mix and match modular led lights fitted to
a fury. They did no come with any type of rear bracket and are they going to be a lot more difficult to fit when the car is already built. I've
looked at mango fury's build but these are different lights to the Hella's.
YQUSTA
| posted on 11/3/12 at 07:01 PM |
IIRC ther are 3-4 holes on the rear of the fitting.
What I did was tap these holes, make up some small pieces of metal bent to go from these holes to the bodywork which then clamped the light in.
I hope makes sense
"If in doubt flat out"
Colin McRae
big-vee-twin
| posted on 11/3/12 at 08:33 PM |
If you go onto Hellfires build diary/blog there is a good guide included there for these kind of lights which I used as guide for mine
[img]
  Rear Lights fitted
[/img]
http://www.triangleltd.com
mazie
| posted on 12/3/12 at 08:57 AM |
Nobody with tips/photo fitting to a fury?
