Author: Subject: duratec alternator
ali f27
posted on 17/3/12 at 05:02 PM Reply With Quote
duratec alternator
Hi thinking about just using standard modaeo alternator on my duratec engine its about getting parts when touring will it work or are they controlled by the mondaeo ecu mine will have after market engine management
Cheers Ali
hootsno1
posted on 17/3/12 at 06:57 PM Reply With Quote
have just bought one off these
A073 5 Groove Pulley Nippon Denso Kit Car Lightweight Alternator | eBay
If a little hammer won't fix it get a bigger hammer
big-vee-twin
posted on 17/3/12 at 07:55 PM Reply With Quote
Depends where you going to mount it I initially used a Micra Alternator which is small but it wouldn't fit (first pic) I then opted for a tiny ND alternator as previously said.
[img] micra alternator - too big
[/img]
[img] ND Alternator
ND Alternator
[/img]
http://www.triangleltd.com
ali f27
posted on 17/3/12 at 09:27 PM Reply With Quote
Hi is that the standard tensioner from the other side
big-vee-twin
posted on 17/3/12 at 10:35 PM Reply With Quote
The tensioner is from a Ford Focus, it is spring loaded the original tensioner is not spring loaded.
[Edited on 17/3/12 by big-vee-twin]
