Gary 7
| posted on 21/3/12 at 04:31 PM |
Lightweight batteries.
Found this on piston heads interesting idea for a locost lightweight battery. Loads on ebay under £30 notes.
http://www.pistonheads.com/gassing/topic.asp?t=623932
big-vee-twin
| posted on 21/3/12 at 04:39 PM |
Odyssey PC680 Lightweight battery
[img]
  Engine Bay
[/img]
http://www.triangleltd.com
FuryRebuild
| posted on 21/3/12 at 05:14 PM |
I swear by varley red-tops.
www.furyrebuild.co.uk
RK
| posted on 21/3/12 at 05:37 PM |
Second the Odyssey PC680, but make sure you drive your car a lot to keep it charged. And don't leave it outside in negative temperatures... Mine
spent more time testing electrical circuits than driving in the car, so it wore out. I replaced it with a (relatively) huge PC925 which is, I think
more suitable for me.
Gary 7
| posted on 21/3/12 at 06:55 PM |
Thanks for the response , but the thread is about using a cheap battery as used in pc backup ,gollf carts and the like .thats the type of battery the
guy has used.
belgian2b
| posted on 21/3/12 at 07:16 PM |
Hello,
Give a look at this :
http://www.super-b.com/
| posted on 21/3/12 at 07:36 PM |
guy has used.
The same guy that says he pampers his car and then buys the cheapest and smallest SLA battery he can find for it? I wonder if his uses engine oil
from the pound shop as well...
These are the same ones used in many jump start packs, and they simply don't have sufficient CCA rating for larger engines IME. I doubt they
will take kindly at all to the charging currents a modern alternator can push out either - so don't let it get flat.
spiderman
| posted on 21/3/12 at 09:40 PM |
pc680 battery £80+ on ebay. So where are the £30 ones and what are they called?
Spider
Gary 7
| posted on 21/3/12 at 10:23 PM |
Do a ebay search for 12v 18ah battery for the same type the guy used in the piston head thread. I have not used one myself, ,just posted a link to
some.body that has.
djtom
| posted on 22/3/12 at 12:44 AM |
Done exactly that in my car. 2l Zetec Turbo with an 18Ah Yuasa golf cart battery in it. Works perfectly, no problem with cranking at all. If I'm
leaving it laid up for any length of time (> 1 month) I put a trickle charger on it, but otherwise it gets the normal (ab)use the rest of the car
puts up with!
Very impressed so far. Think it cost me £23 delivered from ebay.
Tom
Gary 7
| posted on 22/3/12 at 08:05 PM |
Good locost option then , cheers tom
rdodger
| posted on 22/3/12 at 08:14 PM |
guy has used.
Have a read of this thread. It details the rebuild of his Exige. I think pamper is an understatement.
http://www.pistonheads.com/gassing/topic.asp?h=0&f=15&t=574785&mid=85125&nmt=Exige+S1+over%2Dwinter+Refresh
