r1_pete
posted on 24/3/12 at 07:14 PM |
Fireblade / blackbird TPS resistance
I just bought a carb blackbird CDI to convert my CB750 sohc to electronic ignition.
Should have gone for early blade, because this needs a TPS, but for a tenner it was worth a punt.
So, can someone measure me the resistance of the two outer connectins on a honda TPS? I have several GSXR750 TPS' and secondary TPS', so
hoping I can use one of those.
Alternatively, if I don't connect up a TPS will I just get a two dimentional RPM / Advance operation?
Cheers.
Pete.
Autosri
posted on 24/3/12 at 07:24 PM |
not sure if its any help but im pretty sure the one from webcon i fitted to the webers was 2k ohm and when i was looking around for other options they
all seemed to be 2k ohm
posted on 24/3/12 at 08:18 PM |
As long as it is in the normal ball park the resistance shouldn't matter, on all the systems i have encountered 3 wire TPS are wired as
voltage dividers with a 5v supply the ECU sees the output signal is a voltage. between 0 and 5v .
[Edited on 24/3/12 by britishtrident]
