Dick Axtell
posted on 30/3/12 at 08:41 AM |
Xflow Oil Press Switch
Std xflow oil press switch - with threaded brass electrical conection.
Is this a BA thread? If not, can anybody tell me what true thread is?
BTW - original harness connectors were rubber-covered, push-on type. Don't have one for this diameter.
[Edited on 30/3/12 by Dick Axtell]
nilocp
posted on 30/3/12 at 06:08 PM |
Not BA, from memory 1/8 BSP(T).
Colin
Trollyjack
posted on 30/3/12 at 06:21 PM |
Ditto
TrollyJack
posted on 31/3/12 at 07:11 AM |
Can't remember for sure but I thought it might be 1/4 BSP, the same size as the oil gallery plugs?
Dick Axtell
posted on 31/3/12 at 05:32 PM |
BSP??????????????
Surely - that's the thread used for screwing into the block port. I'm needing the thread on the brass stud, for the
electrical connection. BSF/UNF maybe, but which?
nilocp
posted on 31/3/12 at 05:41 PM |
Aah! Now he is being more explicit
No 6 UNF? But I seem to remember that a female bullet just pushed on to it?
I can check on Monday. I have a thread gauge!!!
Colin
Dick Axtell
posted on 1/4/12 at 01:13 PM |
quote: Originally posted by nilocpBut I seem to remember that a female bullet just pushed on to it? I can check on Monday. I have a thread
gauge!!!
Female bullet - Yes!! But as I said in my original post, I don't got any this size left (from the old donor loom). So, I was hoping to use a
bolt-down elec connector instead. Therefore, I need to know the thread. Hope you'll be able to gauge it.
RichardK
posted on 1/4/12 at 02:14 PM |
Think its the same as the screw on ht lead connector on the top of any spark plug I seem to remember, if that helps!
Rich
Gallery updated 11/01/2011
posted on 1/4/12 at 04:43 PM |
Time to invest in a set of thread gauges??
Dick Axtell
posted on 2/4/12 at 09:08 AM |
Have already done so. Just cannot lay my hands on them, at the moment!
Dick Axtell
posted on 2/4/12 at 09:10 AM |
Great - thank you! Will deffo check that out, got some spare old sparkers somewhere in the lock-up. Might even doscover where I've hidden those
thread gauges!!!!
nilocp
posted on 2/4/12 at 04:14 PM |
Well what a wally I am!!!
I have checked the thread on a temperature sender not an oil pressure sender!!!!!
But for information that is 3/16in 40 tpi. Which basically doesnt exist!!!
It is NOT M5, 2BA, BSF, Whitworth, ANC, UNC, ANF, UNF or even cycle thread!!!!!!
So tomorrow I will have a look at an oil switch. (But it probably is the same anyway!!)
Colin
Dick Axtell
posted on 3/4/12 at 08:41 AM |
Thanks for checking. Is there/Was there a specific thread for domestic electrical fittings, i.e. those little brass screws inside plugs & light
switches? Some of the more industrial types have bigger dia threads for their screws etc.
nilocp
posted on 3/4/12 at 04:38 PM |
Dick, Right, I have been through all my oil pressure switches, and all the crossflow ones have got a spade connector! I do have some Pinto ones with a
thread.
These are weird as well. M4 x 0.8, which doesnt exist!! Or it is 5/32 x 32 which is 8-32 UNC. This takes the red bullet, just pushes on.
I hope that helps???
Colin
Dick Axtell
posted on 3/4/12 at 10:25 PM |
Thanks for the additional data. Have tried using the screw collar from spark plug, but it doesn't fit.
However, have successfully used gash nut found in one of my odds-&-sods collections. It does not fit the water temp sensor, however, which
appears to be yet another strange thread!!
