Author: Subject: crank pickup issue
beaver34
posted on 8/4/12 at 06:30 AM Reply With Quote
crank pickup issue
just turned my engine over and im getting no crank signal
its omex 600 using stock ford crank sensor that worked fine before, the setting in the ecu are a base map from omex
ive changed the mx timing either way but to no avail, how do i check the sensor is wired correctly?
thanks
dave r
posted on 8/4/12 at 07:26 AM Reply With Quote
someone on here the other week had the same issues... turned out the supplied loom was wrong
click me
[Edited on 8/4/12 by dave r]
I'd love to give my imaginary friend a great big hug,
but this jacket makes it impossible.
beaver34
posted on 8/4/12 at 09:20 AM Reply With Quote
thank, ill check the loom but im 99% its right as i have run it last year
how do i check for continuity of the wiring?
beaver34
posted on 8/4/12 at 11:27 AM Reply With Quote
fixed, was connector on the end was not a genuine ford one and did not clip on correctly, now just need a fuel pump then should fire up
