bob
posted on 29/8/04 at 06:13 PM |
push button panel
has anyone got the wiring diagrams for one of those push button starter panels with the aero switch knock down cut off ?
I know its not rocket science but it would help me a lot if i had the right diagram.
Deckman001
| posted on 29/8/04 at 07:50 PM |
Bring the switch sat and I'll tell ya what to do
Jason
bob
| posted on 29/8/04 at 08:06 PM |
I'll have a pen and paper too,you know how long winded i am with electrics
marcyboy
| posted on 29/8/04 at 09:04 PM |
no.... but i know how long your wind is !!!
Mikey G
| posted on 30/8/04 at 09:42 AM |
Heres a little simple diagram i have knocked up
not sure if others have done the same but its the easiest solution.
If your keeping your original key switch just put the new switch into the wire that goes to the ignition, then take another wire off the switched side
(as per diagram) and connect it to the one side of the push button. the other terminal then needs to go to the starter solenoid, the wire of this can
be taken off the back of the original keyswitch or just direct to the solenoid.
bob
| posted on 30/8/04 at 09:59 PM |
Thanks mikey
I kinda have it planned the same way still using the key as switch and steering lock for security.
I just like to get opinions of others who have done it before i completely cock it up
Thanks again
