Author: Subject: wireing advice
nige
posted on 24/4/12 at 06:34 PM Reply With Quote
wireing advice
just about to lay out the loom and start
any advice for an electrical novice
best places for fuse box and relays etc
cheers nige
when you start this journey
you think it will be done in " no " time but then " no " turns into a " bloody " long time
jacko
posted on 24/4/12 at 06:46 PM Reply With Quote
If i made another kitcar / 7 type i would fit the fuse box / relays on a drop down flap hinged at the back above the passengers feet under the scuttle
jacko
tomgregory2000
posted on 24/4/12 at 06:58 PM Reply With Quote
just do one bit at a time and its easy
the wiring was one of the things that i put off for almost a year but once i got stuck in doing one bit at a time it was easy, get yourself a multimeter!!
steve m
posted on 24/4/12 at 07:11 PM Reply With Quote
Multimeter is a good idea, but just a bulb with two wires soldered on, and a couple of cheapo crockodile clips is invalueble
maskell01
posted on 24/4/12 at 07:38 PM Reply With Quote
I put mine in the glove box, but mounted them from the back so only the fuzes and holder covers were visible!
macc man
posted on 24/4/12 at 07:57 PM Reply With Quote
Fit a battery isolation switch to kill all the circuits. It could save your loom if you short out a wire. Fit a fuse link to blow first before the component or wire fries. Keep it simple and route cables away from heat and moving parts. Use conduit to insulate cables. Always use a relay for heavy current devices. Good luck.
nige
posted on 24/4/12 at 08:15 PM Reply With Quote
Can i fit a battery isolator in the cabin area
thanks for all the replies i will take note
of every one
cheers nige
snowy2
posted on 24/4/12 at 08:17 PM Reply With Quote
READ this it will help you and it covers the topics you need.....
http://www.andersensmith.freeserve.co.uk/wiringloom6.pdf
sometimes you are the pigeon, most of the time the statue.
posted on 24/4/12 at 08:24 PM Reply With Quote
Have you bought a purpose made loom? If so this will largely dictate the layout and position of most things. Work steady and double check things before applying power.
Personally I prefer the fuses, relays etc positioned under the scuttle to protect from water ingress. I made an ally panel with all these components on and positioned it above the passenger footwell. One tip...it pays to mount mark each fuse with it's circuit function, this makes it much easier and quicker to fault find thereafter.
If you get stuck, just post pics and ask here, the answer will be provided pretty quickly
