Author: Subject: Transit SWB towbar electrics
richardh
posted on 27/4/12 at 02:02 PM Reply With Quote
Hi, was looking at getting a towbar/electric kit for my transit 55plate but apart from varying in cost from £80 to almost £300, can i just use the simple kit type?
I've heard and read about the electrics playing up due to low voltage / GEM / monitoring sensors etc in new vans and cars.
Should i be looking at one of these little "suppression"?? boxes or something?
1) Any ideas on cheap places to get a kit?
2) Does this electrical thing effect me or good to chop and solder into rear cluster wires?
Cheers Peers
Time for a change!
owelly
posted on 27/4/12 at 02:10 PM Reply With Quote
If your Tranny has normal filament bulbs in the rear light cluster, you don't need the 'can-bus' type electronicy box. You may need an uprated flasher unit but I doubt it. If it's possible to buy a sub-loom that will plug into your excisting van loom, for a decent price, then get one. If not, buy the kit (which has the flasher buzzer/beeper warning) from Towsure, Discount Towing, Trailers and Towing, etc and splice into your loom.
http://www.ppcmag.co.uk
owelly
posted on 27/4/12 at 03:00 PM Reply With Quote
http://www.discount-towing.co.uk/product/5245-Towbar-_Ford_Transit_Van_2000-
And I would say the dedicated wiring loom is worth buying at £39, but they're out of stock at the moment...
[Edited on 27/4/12 by owelly]
richardh
posted on 27/4/12 at 03:09 PM Reply With Quote
thanks very much
Time for a change!
