Author: Subject: Dash wiring question
theduck
posted on 27/4/12 at 10:05 PM Reply With Quote
Probably a very simple answer to this, but I want to check before starting.
I have various dash lights I want to wire in instead of using the sierra dash, do I just join them all to a common earth and take the feed from the relevant wire from the dash loom?
Could I do the same I'd I was to use but rehouse the original tacho?
Any pointers appreciated.
tegwin
posted on 27/4/12 at 10:36 PM Reply With Quote
You may well find that most of them require a +ve supply and are actually earthed through the sender/engine block.
Only way is to work through each one in turn and work out how it works in the old loom.
www.verticalhorizonsmedia.tv
FazerBob
posted on 27/4/12 at 10:39 PM Reply With Quote
wiring
[Edited on 27/4/12 by FazerBob]
snowy2
posted on 28/4/12 at 06:48 AM Reply With Quote
The basic answer is no.........
the battery light is NOT earthed...neither is the oil light...
the indicator light if its only one is not earthed either but connected to either sides indicators, but if you have two they are earthed.....
This article will help you sort it all out..
http://www.andersensmith.freeserve.co.uk/wiringloom6.pdf
sometimes you are the pigeon, most of the time the statue.
theduck
posted on 28/4/12 at 09:09 AM Reply With Quote
Thank you guys, can crack on with it now today
