001Ben
posted on 13/5/12 at 11:36 AM |
FS: Samco Hoses & Alloys
Having a clear out in the garage and found a number of things that i no longer need. Will offer on here before they go on ebay.
Stainless stube with a 90 degree bend. Leg lengths 37.5cm. I/D is 70mm , o/d is 75mm - £15
Samco 51mm hose joiner, part number AJ51. Brand new. £8. It’s the same as SAMCO SILICONE 51MM ALLOY JOINER | eBay
Samco 90 degree hose. I/D 76mm, O/D 83mm – leg lengths 17cm – slight pen mark otherwise new. - £15. It’s the same as SAMCO SILICONE 76MM BORE 90
DEGREE ELBOW | eBay
Samco 180 degree hose. I/D 76mm, O/D 83mm – total height 16.5 cm. Distance between centers 23cm – new - £25. It’s the same as SAMCO SILICONE 76MM BORE
180 DEGREE ELBOW | eBay
14" Alloy Wheels and tyres - continental sport contact tyres 165/60/R14
Ford PCD
5J 14 Offset 36 £50
U2U me if you need any more info
[Edited on 13/5/12 by 001Ben]
AntonUK
posted on 13/5/12 at 12:04 PM |
are the wheels ford PCD?
Build Photos Here
001Ben
posted on 13/5/12 at 12:07 PM |
yes they are ford pcd
