clairetoo
posted on 27/5/12 at 05:34 PM |
Crank sensor wiring
I'm uing a Ford VR crank sensor on my V6 Mazda , as I cant work out how to use the stock hall effect (3 wire) sensor - but I am stuck on the
final connection .
There are only two wires , but which is `positive' ? I know it matters which way round its wired , but other than trial and error how can I
figure this out ?
Help
Its cuz I is blond , innit
Claire xx
Will weld for food......
Hector.Brocklebank
posted on 27/5/12 at 07:08 PM |
I thought the 3 wire hall effect went as follows on a megasquirt.
1, 12v supply required from a ignition live or "Vref" on megasquirt
2, Earth which would go to the "common" sensor earths on megasquirt
3, Output signal, which is usually pin 24 on megaquirt
For the VR sensor this was covered in a thread you contributed to back in 2009
!!!Here
I hope that helps
Some people can never handle the truth and always try to shoot the messenger instead of taking an honest look in the mirror (its always easier to
blame another than to face reality), but secretly they wish they could grow a pair and be the messenger !!!
clairetoo
posted on 27/5/12 at 07:21 PM |
I had intended to use the hall effect sensor - but as I am running Edis I cant see how it would work
But - thanks for the heads up , that solves the problem of connecting a VR sensor plug - I allready have it wired at the Edis end .
Claire xx
scudderfish
final connection .
figure this out ?
Help
It does matter which way round, but if you get it wrong you won't damage it. If you don't get an RPM signal, just swap it over.
avagolen
posted on 27/5/12 at 08:40 PM |
Hi Claire,
If you follow this link, you will end up with a picture and text from FLAKmonkey.
Ignore the text, it confuses the issue....
The picture (he assures me) is correct.
http://www.locostbuilders.co.uk/viewthread.php?tid=112060
Have fun,
Len.
[Edited on 27/5/12 by avagolen]
clairetoo
posted on 27/5/12 at 09:00 PM |
I followed the link - pictures now saved and problem sort of solved - I've had to buy a VR sensor off ebay and wont know till it arrives if I
can make it fit my engine
Claire xx
