Author: Subject: EV6 Injector connector disassembly
se7ensport
posted on 22/6/12 at 08:15 PM Reply With Quote
Looking for some advice on disassembly of an EV6 injector connector, how do I remove the red insert?
EV6 Connector
EV6 Connector
I assume that once it's removed it is the same as other AMP style connectors in that a small flat head screwdriver will release a plastic tab allowing the metal crimped connector to be removed from the back of the housing.
[Edited on 22/6/12 by se7ensport]
