Author: Subject: Battery Isolator.
stevegough
posted on 1/7/12 at 07:31 PM Reply With Quote
Battery Isolator.
Well, after looking with horror at the sad end of Hicost's car in the Pyrennees, I have just spent a few hours trying to ensure mine doesn't suffer the same terrible fate.
I have fitted an isolator (which can do treble duty) -
1 - isolates the battery (earth - to negative pole) in case of in-dash fire.
2 - isolates the leccies when the grandkids are faffing about in it.
3 - theft deterrent.
Already passed IVA, so I have no need to ensure the blinkin' hazards still work while isolated!
As I had planned to remove the dash to fit a 12v socket for the Tom Tom, it seemed a good time to do it.
Obligatory picture....
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
Westy1994
posted on 1/7/12 at 07:45 PM Reply With Quote
I was going to put mine in there, but then thought about stuff that might roll about in the box and switch it off mid corner... Ended up in the same area but under the dash instead. Nice tidy job though Steve.
Rich
matt_gsxr
posted on 1/7/12 at 09:38 PM Reply With Quote
Good work. Battery cut-off is a very nice little modification for a project car.
Provides some theft protection and is nice to have when messing with electrics too.
Some folk have suffered with intermitent failures on these but so far I haven't seen this.
coyoteboy
posted on 1/7/12 at 09:46 PM Reply With Quote
Just curious about the IVA comment - surely a battery isolator is not part of the IVA test, so all you have to worry about with that is when the ignition is off the hazards work, isolator is a whole other ball-game that doesn't need to be included in the test? Or am I just thinking wishfully?
stevegough
posted on 1/7/12 at 09:51 PM Reply With Quote
Well, you've answered your own question, really.
No, an isolator isn't needed for the IVA, but if you fit one, the hazards must always be able to work.
(bit daft really, as current is still flowing through wires and a relay behind your dash - its hardly isolated!)
Luego Locost C20XE.
Westy1994
posted on 1/7/12 at 09:53 PM Reply With Quote
No, I think you are correct, the whole point as I see it for having an isolation switch is just that - it isolates the entire battery supply from the rest of the car.
Regarding the IVA part, not sure about as that does not concern my car, but I bet there is a rule about sharp edges , I was watching a re-run of the 'Racecar is born' series, and I had to laugh at the bit where he gets it ready for the test, putting trim around the rear number plate bracket....C'mon !!!.
Westy1994
posted on 1/7/12 at 09:59 PM Reply With Quote
So, if you have a switch hidden away somwhere out of sight, I assume the Hazards just need to work as normal - ie with the Ign off.
AS you say, defeats the whole point of the switch otherwise, very odd.
stevegough
posted on 1/7/12 at 10:00 PM Reply With Quote
That guy is great at what he does, but you have to remember, its TV - not real life. I agree its bleedin' corny in places!
Now read the true story......just posted by the guy in the know. Kit car crisis
[Edited on 2/7/12 by stevegough]
Luego Locost C20XE.
coyoteboy
posted on 2/7/12 at 08:40 AM Reply With Quote
Think I'll just leave it off until after the IVA.
matt_gsxr
posted on 2/7/12 at 08:50 AM Reply With Quote
For IVA you can cut down one of those red keys (the non-FIA ones are best for this) and slot the top so it only turns with a screwdriver. So now you need tools to change its state (it is no longer a switch).
Then leave it in the on position for the test.
That is what I did and they were happy.
stevegough
posted on 2/7/12 at 08:57 AM Reply With Quote
Sounds like a good idea for the test, Matt - but I have a vision of smoke building up, and frantically hunting in the boot for a screwdriver......I think I'm leaving my key exactly as big as it is now!
Luego Locost C20XE.
coyoteboy
posted on 2/7/12 at 09:07 AM Reply With Quote
Doesnt have to remain cut down...
Macbeast
posted on 2/7/12 at 11:58 AM Reply With Quote
Just to clarify -
Kitcar Crisis was Mark Raynard- apparently a plonker.
A Car Is Born etc is Mark Evans - all-round good guy.
coyoteboy
posted on 2/7/12 at 02:20 PM Reply With Quote
Just to clarify - Kitcar Crisis was Mark Raynard- apparently a plonker. A Car Is Born etc is Mark Evans - all-round good guy.
Just to clarify, wrong thread
Macbeast
posted on 3/7/12 at 11:04 AM Reply With Quote
No it's not :p
" I was watching a re-run of the 'Racecar is born' series, and I had to laugh at the bit where he gets it ready for the test, putting trim around the rear number plate bracket....C'mon !!!.
Now read the true story......just posted by the guy in the know. Kit car crisis ""
Reads to me as if he's saying Mark Evans was involved in Kit Car Crisis
Westy1994
posted on 3/7/12 at 03:05 PM Reply With Quote
Originally posted by Macbeast
No it's not :p
Have you been smoking something , I don't see any reference to Mr Evans in that thread at all.
EDIT TO ADD,
Ahhh, I see what you mean now, having just re-read THIS thread as opposed to the Crisis thread, yes in a way you are correct and it does indeed sound like Mr Evans was something to do with it...which he wasn't..
[Edited on 3/7/12 by Westy1994]
James
posted on 3/7/12 at 04:05 PM Reply With Quote
If I can cruelly drag this thread back on topic!
Why have you used the switch to isolate the earth rather than the live?
James
coyoteboy
posted on 3/7/12 at 04:06 PM Reply With Quote
WHOOOSH. Right over my head.
