mikeb
posted on 19/7/12 at 10:45 AM |
Positive Battery terminals, reducing number of wires
I'm running a small odessey battery and currently have 4 cables going to the positive terminal (m6 bolt)
There's two from the loom, one to the starter and one from the alternator.
This isn't going to make for a neat solution under the bonnet, I've seen some pictures with just one connection, is there a bus bar type
arrange people are using?
M
Davegtst
posted on 19/7/12 at 10:54 AM |
I used one of these. I have one cable from the battery positive to the joint box which is hidden under the scuttle.
Joint box
mikeb
posted on 19/7/12 at 11:16 AM |
perfect I know there would be something, they do a 3 bolt one to which would be perfect.
Mr Whippy
posted on 19/7/12 at 11:20 AM |
Cool just what I need for the Landy too thanks to the winch
ta
mad4x4
posted on 19/7/12 at 12:25 PM |
Yeah I was going to use an "Exhaust rubber mount" from a Mini ... thats better.
Scot's do it better in Kilts.
Chippy
posted on 19/7/12 at 04:05 PM |
Well you can reduce it by one, just by connecting the alternator to the starter motor, charge will still get to the battery just fine. HTH Ray
owelly
posted on 19/7/12 at 04:11 PM |
I have one cable from the battery post to the cut-off switch then the other cables off that.
http://www.ppcmag.co.uk
macc man
posted on 19/7/12 at 06:32 PM |
As above keeps it tidy.
posted on 19/7/12 at 07:44 PM |
I ran a short cable from the alternator to the starter, no issues at all... in fact I've got a Focus positive cable here that is one piece with
a terminal in the middle for the starter.
