Author: Subject: Flatshifter wiring
maccmike
posted on 3/8/12 at 06:43 PM Reply With Quote
Flatshifter wiring
Hi, If I want to create an ignition cut, where on the following diagram do I break into?
Thinking of a micro switch on the gear lever to activate it.
[img]
[/img]
[Edited on 3/8/12 by maccmike]
maccmike
posted on 3/8/12 at 06:46 PM Reply With Quote
would it be the pick up coil?
Andy B
posted on 3/8/12 at 07:09 PM Reply With Quote
I would cut the red power supply to both coils and route that through the switch, you will need to put a feed back in for the ecu but that's pretty much how the flat shifters work
Regards
maccmike
posted on 3/8/12 at 07:53 PM Reply With Quote
Hi Andy, thanks for that.
It doesnt have an ecu as such, just a junction box and igniter unit.
Off that diagram, in laymen terms to me, how would you do it?
maccmike
posted on 3/8/12 at 10:38 PM Reply With Quote
bump
Andy B
posted on 3/8/12 at 11:28 PM Reply With Quote
Sorry my poor description - pretty much as I said but if you look the ignitor shares a common power feed as the coils, cut the red power to the coils and re route through the switch, at the same time reinstate a power feed to the ignitor upstream from the ignition cut
Regards
maccmike
posted on 3/8/12 at 11:55 PM Reply With Quote
thanks mate, would I cut in between the ignitor and the coils side or starter button and coils side?
maccmike
minitici
posted on 4/8/12 at 08:30 AM Reply With Quote
As Andy says - cut the +12V feed going to both coils (red wire) as per this diagram:
zzr coil wiring
zzr coil wiring
As a matter of interest how are you proposing to initiate the ignition kill?
Most flatshifter systems have a kill time of about 60ms and some have lock-outs to avoid multiple kills.
maccmike
posted on 4/8/12 at 08:39 AM Reply With Quote
thanks for that.
dont know yet lol
