matty h
posted on 14/8/12 at 09:36 PM |
Separate front sidelights
Looking at fitting some 5 3/4 round headlight unit to my seven but do not have sidelights built in what separate sidelight units are everyone
using.
Seen these but want to know what else is available.
2 Button 12v Hyper Bright White LED lights Sidelight | eBay
Thanks Matty
maccmike
posted on 14/8/12 at 09:42 PM |
i quite like those
steve m
posted on 15/8/12 at 07:39 AM |
Is your car already on the road? as if it isint i doubt they would be SVA compliant/ E marked
matty h
posted on 15/8/12 at 08:34 AM |
Yes car is already on the road just changing from 7 inch lights to 5 3/4 but messed up and got units without a sidelight.
loggyboy
posted on 15/8/12 at 08:41 AM |
No that is relevant, as it is on the road!, but aslong as the angles etc are met, and the brightness is similar to that of an E marked light theres no
reason they wouldnt pass IVA.
Mistral Motorsport
loggyboy
posted on 15/8/12 at 08:43 AM |
A bit more expensive but I quite like the look of these for sidlights.
Pair LED projector lens button bolts white leds, CNC black case no plate light | eBay
Mistral Motorsport
snowy2
posted on 18/8/12 at 10:07 AM |
strictly speaking your car should comply with the requirements of the SVA/IVA at all times and altering after the test to a standard that does not
comply is illegal.....now i know the chance of being caught is limited....... how ever i do know that some police forces are getting wise to this
practice and are doing checks on some kits they stop. the most common fine is for illegally placed headlights.
sometimes you are the pigeon, most of the time the statue.
