Author: Subject: INDICATOR STUCK ON
AllWeatherDan
posted on 23/8/12 at 12:39 PM Reply With Quote
INDICATOR STUCK ON
Hi All,
Set off to work this morning in the Tiger (CAT E! PINTO)
Had to turn around as the right indicator was constantly flashing.
This could not be rectified by WIGGLING (technical term) the indicator stick.
In short had to use the Landy for work today! GUTTED!
Any ideas
Dan
There is no such thing as a stupid question.
Just the ones I ask!
mookaloid
posted on 23/8/12 at 01:25 PM Reply With Quote
Needs a new indicator stalk? they get full of fluff and crud and the grease goes hard which has an adverse effect on the operation of the switch.
Indicator relay seized?
got to think it's probably one of those
AllWeatherDan
posted on 23/8/12 at 01:42 PM Reply With Quote
Thanks,
I will have a look tonight.
Dan
maccmike
posted on 23/8/12 at 03:56 PM Reply With Quote
disconnect it and use your hands!!
tomgregory2000
posted on 23/8/12 at 04:36 PM Reply With Quote
I had the same problem and got myself a can of contact cleaner and gave it a good squirt and a wiggle and it worked
big-vee-twin
posted on 23/8/12 at 05:51 PM Reply With Quote
You can dismantle the switch to give it a good clean so long as you are careful and note where the springs go, mine didn't work and i opened it up works fine now
http://www.triangleltd.com
posted on 23/8/12 at 07:03 PM Reply With Quote
If it's a Sierra switch it's fairly common due to damp getting in the switch, as said try some contact cleaner or maybe even some WD40
austin man
posted on 23/8/12 at 08:36 PM Reply With Quote
mine did it there are two little rolles that had collapse I modified mine to negate the need for the rolers
