belgian2b
posted on 1/9/12 at 03:15 PM |
battery selection
Hello,
i am looking for a battery for the Tiger Cat that i am building.
Engine is Sierra 2.0 EFI SOHC.
I can find the standard battery , and even if it will fit perfectly in the car (dimension 242 x 175 x 175 mm), i have a problem because, the + is on
the right but i would like to have the + on the left.
So , can anybody give me a reference of a identical battery but with + on the left ?
thanks in advance,
Gerardo
Staple balls
posted on 1/9/12 at 03:28 PM |
Can you not like, turn it around?
spiderman
posted on 1/9/12 at 03:38 PM |
Turn it around by 180 degrees terminals will now be the right way round for what you want but at the back of the battery, if that helps.
If not;
Halfords HB015, HB072
those are the ones I have with the +ve on the left.
Spider
flibble
posted on 1/9/12 at 03:51 PM |
Type 078 (alpha romeo 75) measures 242mm x 173mm x 188mm, so 11mm taller is closestI can find?
posted on 1/9/12 at 04:37 PM |
There is likely to be a variant with reversed terminal layout but it won't have Ford bolt through lug terminals for example type 076 or
Type 077 or type 058.
You will probably have to buy a big name brand such as Exide or Varta for an unusual terminal layout.
Tayna batteries should help
http://www.tayna.co.uk/battery-search-48-218-0-0-0-0x175x0-10-4-1-batteries.html
belgian2b
posted on 1/9/12 at 06:07 PM |
Hello all,
thank for advices,
i found what i was looking foron the last mentionned website :
this is what i will use : AM058R Numax Car Battery 12V 57AH
Gerardo
snowy2
posted on 1/9/12 at 08:10 PM |
there is a lot of nutsack spoken about battery size + amps etc.......the battery on my car which is also a 2.0L pinto uses a fiat Punto battery, its
tiny only about 6" square and works just fine.
interesting censoring software on this site.....B****KS come back as nutsack??? hows that better?
[Edited on 1/9/12 by snowy2]
sometimes you are the pigeon, most of the time the statue.
rdodger
posted on 1/9/12 at 09:17 PM |
Not wanting to sound pedantic but........ surely b***ks are the content of the nutsack?
snowy2
posted on 2/9/12 at 06:44 AM |
amusing though isn't it?
on another forum i use the interior of our cars cannot be named a cockpit. and another of our members has trouble giving his location
out....Scunthorpe.
