danro
posted on 14/9/04 at 02:15 PM |
Keyless ignition
Has anyone done a keyless ignition system?
I quite fancy the idea of flicking a switch, a numeric keypad to punch in a number then press the red button to start the engine.
Perhaps a soleniod do the steering lock?
Am I missing something really obvious here or is it 'doable'?
I have only a basic knowledge of electrics so any comments will just add to the leaning experience
OK....hit me with it!
scoobyis2cool
posted on 14/9/04 at 02:59 PM |
I don't see any reason why it wouldn't be possible, I think the reason it hasn't (I'm assuming) been done before is because 7
style cars are obviously quite easy to climb into, and therefore your only line of defence from would-be car snatchers is the fact that they
haven't got a key. If they managed to get hold of your code then it wouldn't take much for them to steal it.
I'll be interested to see what anyone else has to say because keyless ignition sounds good to me too, but I've avoided it for the above
reasons
Pete
Bob C
posted on 14/9/04 at 03:13 PM |
Solenoid steering lock sounds very frightening indeed! It would have to be electrically held off....
My brother converted a yank TR6 back to right hand drive & the steering locked on him, reckons he aged 10 years in 3 seconds before he was able to
brute force the car back into control. The earth strap from the battery had fouled the column UJ
I'm fairly frightened by the sierra steering lock on my column(!) I guess it must be OK......
Bob
splitrivet
posted on 14/9/04 at 03:16 PM |
Maplins do a velleman kit thier part number ve76h which included a number pad and relay which would do the job,which we used to use for door
entry.Dont know if its still current failing that they do several remote kits which would also do it for not much money.
Bob,
Dale
posted on 14/9/04 at 04:16 PM |
for a solinoid steering lock my sugestion would be a manual locking pin that a solinoid unlocks to allow you to unlock the wheel but if the solinoid
reengages it will not lock your steering untill youmanually relock the wheel.
Dale
Northy
posted on 14/9/04 at 05:53 PM |
How about one of the alarms that disarms just because you've got the transponder in your pocket?
I think they are cheap on Ebay. Has anyone used one? Or have any experience? I fancy using one.
Graham
spunky
posted on 14/9/04 at 09:47 PM |
I have a keyless system, thats to say there is no ignition barrel or conventional key. Just a button transponder that you touch on the dash to switch
the ignition on ( like those used on some pub cash tills)
I wear it as a necklace 'cos I'm paranoid about loosing it.
John
The reckless man may not live as long......
But the cautious man does not live at all.....
twinturbo
posted on 15/9/04 at 05:08 AM |
What are the SVA requirements?
TT
spunky
posted on 15/9/04 at 06:34 AM |
TT
SVA simply requires an anti theft device to be fitted. Either mechanical or electrical, this in addition to a steering lock/ignition key. I fitted a
battery isolator, which seems a popular choice.
John
Rob Lane
posted on 15/9/04 at 07:25 AM |
When did they add steering lock/ignition key?
As far as I was aware it only called for an 'anti-theft device' in addition to normal 'ignition switch'. This switch was not
defined and a flip switch was acceptable with further anti-theft measures. Electronic or otherwise.
[Edited on 15/9/04 by Rob Lane]
DaveFJ
posted on 15/9/04 at 08:00 AM |
I thought SVA required two seperate devices - one of which to be mechanical and niether capable of being 'switched on' whilst the engine
is running ?
Dave
Rob Lane
posted on 15/9/04 at 08:08 AM |
This is what I have BUT it may have been updated, hence my question.
Extract:
Security
1. Check, in addition to the normal "ignition" switch, the vehicle is permanently fitted with an "anti theft" device that can
be activated to prevent the vehicle being driven or moved under its own power.
The device may be mechanical, electrical or electronic or a combination of these.
2. Check the operation of devices and their interaction with any system that affects the control of the vehicle.
danro
posted on 15/9/04 at 08:22 AM |
Cool!!!
Those transponders are only £9.99 'buy now!' on Ebay!! (or £40 for a toad one)
That is probably better than the keypad.
I agree that the solenoid for the steering lock could be a bit dodgy - that was one reason I decided to air my thoughts.
From what I can gather from Spunky I do not need the steering lock if I use a battery isolator? What is you isolator like? A big red twist switch like
the ones fond in the race series or is more subtle?
[Edited on 15/9/04 by danro]
spunky
posted on 15/9/04 at 11:15 AM |
Sorry didn't make it very clear. Steering lock is not a requirement.
John
spunky
posted on 15/9/04 at 05:02 PM |
It is a big red switch with a hi load resistor connected behind the switch to protect the alternator. It is positioned descreetly between the seats
though
John
ned
posted on 16/9/04 at 08:44 AM |
I've seen battery kill switches located hidden under the dash and even externally inside/under the front nose cone..
Ned.
beware, I've got yellow skin
