Author: Subject: points and coil wireing
steve m
posted on 9/10/12 at 08:02 AM Reply With Quote
I am trying to sort a missfire out, and have ditched the lumention for points and condensor, just for a trial
even if this doesnt cure the problem, i will still carry the points as a back up
But, for the life of me, i can not remember the wiring diag
in my circuit i have
one distributor
one coil + and - connections
electric rev counter
This is all standard ford wiring
snapper
posted on 9/10/12 at 09:57 AM Reply With Quote
Google is your friend
Wiring
I eat to survive
I drink to forget
steve m
posted on 9/10/12 at 11:04 AM Reply With Quote
Thanks!
I did try searching, but that one is exactly what i want!
regards
steve
snowy2
posted on 9/10/12 at 08:04 PM Reply With Quote
Missfire....often weak mixture or air leak....check inlet manifold gasket.
sometimes you are the pigeon, most of the time the statue.
steve m
posted on 9/10/12 at 08:14 PM Reply With Quote
Missfire, was caused by a new carb gasket that was thinner in the middle, and allowing air in
only found it by spraying easy start about!!
All fixed now, with thicker gaskets
